  1. othmane
    othmane New Member
    77Coins
    hi does any one know anything about the AMC-MDBOX controller??
  2. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Good day Guys.
    I don't know what I'm doing wrong, I have Loaded SMC3 Version 1 on my arduino connected my to IBT2 BTS7960 43A bridge H, Change the cod in the Arduino to mode 2.
    Opened the SMC3 Windows utility the utility connects to the arduino board with no issues I followed the instructions on the first post to the letter but the motor does not move when I increase the PWMmax, I have also tested the potentiometers and moved them by hand and the green line on SMC3 moves but i cannot get the motors to turn.
    I also used the wiring diagram for mode 2 on the first post and double checked it multiple times.
    If i connect the motors directly to 24v they work perfectly.
    Thanks in advance for the assistance
  3. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Can you post us some screenshots or better a video which shows the setup and the problem ?
  4. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    I will make a video tonight when i'm back home and post it.
  5. hooshang
    hooshang Active Member
    275Coins
    this have to be done in SMC code?
  6. yobuddy
    51,524Coins
    Yes, in the firmware for the interface you are using.
    btw, @Thanos has a controller for such a sim setup.
  7. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Hi Arazok here are the images of my setup.
    when i connect the motor directly to the powersource the motor turns but when i run it trough the motor controller board and the arduino nothing happens
  8. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Hey guys
    I found the issue last night, The power supply we were using was giving 24v when not connected to anything but the moment we connect them to the motor driver boards it reads 33v no idea why. So I'm assuming the boards are going into over voltage lockout as the IBT2 boards have over and under voltage protection.
    I connected a 12v power supply to test and everything started working as it should however my motors are not running as good as they can, I will buy a new 24v PSU 350W should do the trick that is around 14.6A.
  9. hooshang
    275Coins
    congratulation about the effort but your setup doesnt seems very tidy so try to duble checks all wirring and connections and take a look of cold soldering...then IMO separate the potenciometers from motors and test if it was OK then put in the place.
    change the SMC utility as picture below first and then change it as desire.not bad if you also checks motors ground.
  10. Cartman_SP69
    Cartman_SP69 Member
    IT
    South Africa
    384Coins
    Thanks a Mil yes I'm going to clean up the setup once everything works I'm using the jumper wires just to do the tests with as they are easier to remove when troubleshooting. Once everything is ready to go and working I will clean it up and permanently solder everything in place.
    I'm also going to be 3d printing a box to contain all the electronics with cooling for the motor drivers.
  11. Jean Paul Andrade
    Jean Paul Andrade Member
    272Coins
    hello, Im a beginer and after some time looking for the best setup for a 3DOF sim i found your post and I decided to use it to build my own, the only thing is not very clear to me is: the 3 motors are for PITCH, YAW and ROLL movements? i would like to be sure I already have the structure and electronics but i still dont understand deeply the software. i really apretiate your help. thanks
    153,734Coins
    SMC3 can drive up to 3 motors, but what axis they are depends on the physical desing of the simulator, not the SMC3 Arduino code.
    SimTools is where you actually set up motion profiles and it can simulate more than the actual 3 axis, even on a 2DOF you can have sway, surge, heave, pitch and roll.
    It does take some time researching to get your head around the fundamentals of motion simulation and building a rig.
    You will find plenty of helpful information to get you started in the FAQs: http://www.xsimulator.net/community/faq/
    When you are ready please start your own project threads here and post any questions you have on it: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  13. Jean Paul Andrade
    272Coins
    Thank you so much for answering and clear my doubt. I see there's a lot of information, i'll follow your advice, thanks again
  14. phongshader
    phongshader New Member
    39Coins
    Can I run the sketch on the 1st page on a Arduino Mega? would the pin out remain the same?
  15. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,291Coins
    Hey guys,
    I want to add some micro switch to limit my actuator, how are you guys actually connecting them? does SMC3 support it? or we do it another way?
  16. tuanlai
    tuanlai New Member
    Vietnam
    185Coins
    Hi everybody. i have try SMC3 with IBT-2 H-bridge, 12V wiper motor
    I do step by step with SMC3 but motor not moving.
    I can see the green line (pot) moving when i turning pot by hand
    but the yellow line did not moving, im i missing some wired?
    Need your help pls
    I also change "#define MODE1" to "#define MODE2" then upload
    153,734Coins
  18. tuanlai
    tuanlai New Member
    Vietnam
    185Coins
    Thanks for answer me. i resolved my problem, its bad wiring conection pot so its moving not like it should be..
  19. XaviAlonso
    XaviAlonso Member
    España
    103Coins
    Hi everybody ! Firts to first!
    Thanks all of yours for such a amazing forum.
    I build a one axis motion with arduino and motormonter with simtools
    All looking good! Funtions and reaccion
    But! ( yes a but! )
    Right now im using the surge on the iracing
    For the inertia of aceleration and desaseleration. And react really good
    But its a way to exaggerate a littel more the upcoming data or the data send to arduino?
    I mean i try to multiply the data come out in the interface on simtool , output
    [A<axis1>*2]. But nothing happens
    I want to amplify the data a littel .
    Its a way? Maybe on the SMC3 utility?
    Ah! And other question, i can revers the efects? Because its okey but in the opposite way :)
    Thanks guys for your time.
    Xavi
    153,734Coins
    You use the SimTools Tuning Center to modify your surge effect. The lower the value the sharper the response, but over a smaller range, which is what it sounds like you are seeking.
