assetto problem
Discussion in 'Assetto Corsa' started by tmp, Apr 23, 2019.
  1. tmp
    tmp Member
    295Coins
    2DOF, 3DOF, Arduino, SimforceGT
    I have a problem and I have done everything according to the manuals, and I can not get away with it properly corsa, you know if there is a problem I have the purchased version and I do not know what happens to me. what if I have noticed that simtools I have it in green never comes out in blue as before and then green. if you can give me a hand I can buy the program and everything and I am not able to make it work.
    Greetings and thank you
    152,307Coins
    +11,070 / 56 / -2
    Can you please clarify if you are using the demo version of SimTools or a licensed version of SimTools.
    If you are using the demo version of SimTools then only Live For Speed will work and the plugin for it comes pre-bundled. If you are using a licensed copy of SimTools then please post pictures of all of your settings.
  3. tmp
    tmp Member
    295Coins
  4. tmp
    tmp Member
    295Coins
    [Quote = "noorbeast, mensaje: 177484, Miembro: 10786"] ¿Puede del Si està aclarar utilizando la versión de Demostración de SimTools O Una versión con licencia de SimTools?
    Si està utilizando la versión de Demostración de SimTools, Solo Live For Speed funcionará y el complemento Viene preinstalado. Si està utilizando Una copia con licencia de SimTools, por favor, publique imagenes de todos SUS AJUSTES. [/ QUOTE]
    [Attach = full] 61819 [/ attach] [attach = full] 61820 [/ attach] [attach = full] 61821 [/ attach] [attach = full] 61822 [/ attach] [attach = full] 61823 [/ attach] [attach = full] 61824 [/ attach] [attach = full] 61825 [/ attach] [attach = full] 61826 [/ attach] [attach = full] 61827 [/ attach] [attach = full] 61828 [/ attach] [attach = full] 61819 [/ attach] [attach = full] 61820 [/ attach]
  5. tmp
    tmp Member
    295Coins
  6. tmp
    tmp Member
    295Coins
    Las fotos paso tienen si alguien me puede ayudar gracias a
  7. tmp
    tmp Member
    295Coins
    step photos have if anyone can help me out thanks to
    152,307Coins
    +11,070 / 56 / -2
    Does everything work as expected in SMC3, if not go back to its instructions as SMC3 must be correctly set up.
    If SMC3 works as expected then check SimTools is working in Output Testing.
  9. tmp
    tmp Member
    295Coins
    152,307Coins
    +11,070 / 56 / -2
    Have you tried UDP passthru in SMC3.
  11. tmp
    tmp Member
    295Coins
    UDP what do you mean tell me how it is done and I try it.
    thank you very much companion
  12. tmp
    tmp Member
    295Coins
    you mean you put the mc3 domde puts upd no?
  13. noorbeast
    152,307Coins
    +11,070 / 56 / -2
  14. tmp
    tmp Member
    295Coins
    ok I put it and I say thank you very much
  15. tmp
    tmp Member
    295Coins
    I still do not know what I'm going to do. would you mind if I downloaded a program that you use my pc from your home and look at your credit as I do you would do me a favor?
    grace
