Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.1.0.1 pointer update
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    4,964Coins
    It's normal, because you must feel the force on the opposite when the ship slow down. It was like that too pre-patch
    What are the exact value? 20 is quite big
  2. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,919Coins
    3DOF, DC motor, Arduino, 6DOF
    I tried to use the thrust up until I reach the value of twenty. It goes up extremely rapidly and keeps on growing. When I release it, it goes in the opposite direction and I recorded -14. Yes, it quite high.
    My rig is shaken quite a lot.
  3. Wagnard
    Wagnardsoft
    4,964Coins
    This is only in SRV? ship is ok?
    If so, change the % of force in the XML for the problematic value
  4. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,919Coins
    This is exactly what I'm doing right now. So far, I went down at 25% and I am reversing the pitch, maybe the roll too but I'm not yet sure.
    The up/down left/right thrust had to be tone down, even for the ship. I did it in hexapod interface.
  5. Wagnard
    Wagnardsoft
    4,964Coins
    It does happen to me too to reach 14 on SRV when thrusting up, but I think it was like that before. Because I overwrite the XML value you have it changed your last configuration.
    Anyway theses are the value that the game give us. Unless there is another one I didnt catch, we cant really do anything about excel modifying the force via XML or the Tuning center (but this will also affect force on the ship so kinda out of the equation).
    Will check more on the weekend, but I think theses are the values that we are stuck with.
  6. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    7,919Coins
    At least, we have values to work with. It's a bit of experimentation, but we've seen worst.
    Thanks.
  7. ThatGuy
    ThatGuy New Member
    7Coins
    I'm not able to get any motion while running ED. I currently have the most recent EliteDangerous64_Offsets.xml file placed in AppData\Local\SimTools\GamePlugins, is this correct?
    I'm running a dofreality H3 with EliteDangerous64_GamePlugin.dll from 2/19/2019. I can get most racing sims running properly, though am having issues getting any flight ones working.
    Also, thank you Wagnard for the tip on deleting wow64ext.dll from the plugins folder as that fixed the crashing Game Manager for me.
  8. 4apaev
    4apaev Member
    Media
    Moscow, Russia
    486Coins
    Ship is fine, SRV a bit bumpy, but still playable. Thanks!
  9. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    810Coins
    Ship works fine, no movement with SRV though
    Thanks for the fast update @Wagnard !
  10. Wagnard
    Wagnardsoft
    4,964Coins
    Try it a few time, go in and out of the SRV, tell me if you get movement that way.
  11. splendiddd
    CCTV security
    Netherlands
    810Coins
    Sorry no luck. you mean in and out of ship right?
    Edit: also no data in tuning center when in the srv
  12. Wagnard
    Wagnardsoft
    4,964Coins
    yes. Look like I need better values :/
  13. splendiddd
    CCTV security
    Netherlands
    810Coins
    Let me know when to test
    Thanks!
  14. David s wan
    David s wan New Member
    154Coins
    I'm not sure if anyone can help me, I'm using the XML plugin, my game is patched and simtools realize my elite dangerous is running....but I'm getting no telemetry feel back at all, on tuning center when I select "capture min/max"....all my game data output are reading zero....so I guess I'm not getting telemetry from the game?
  15. Wagnard
    Wagnardsoft
    4,964Coins
    A little update for SRV. Let me know if theses works or not.
    Like said previously, go in and out of the SHIP if it doesn't work first time just to be sure.
  16. Piotr Janta
    Piotr Janta New Member
    Poland
    17Coins
    2DOF, SCN6
    ED is not working in my 2 dof platform anymore but I not so experienced with Simtool. Droped today new ED64.. offset.zip file to Simtool Plugin Updater and still no movement after game update. Works before game update. What I'm doing wrong ?
  17. Wagnard
    Wagnardsoft
    4,964Coins
    Can you give me access via Teamviewer so I can check at distance? you can PM the ID & Password if you are interested.
  18. Wagnard
    Wagnardsoft
    4,964Coins
    For information, it is better that you extract the XML from the .ZIP and replace the file manually directly into :
    C:\Users\<YOUR USER>\AppData\Local\SimTools\GamePlugins
    And do NOT re-patch as this will put back the old XML.
  19. Piotr Janta
    Poland
    17Coins
    2DOF, SCN6
    thank you for your quick help !
  20. Piotr Janta
    Poland
    17Coins
    2DOF, SCN6
    after some testing looks like roll & pitch axis dosnt work, its sometimas happen before when my udp port was not open ( like in IL 2)
    should I add in game config any "port" line for telemetry ?
