Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.3.0.0 pointer update
  1. David s wan
    David s wan New Member
    154Coins
    so which plugin should i use alone with this? or just extract xml file? sorry for the n00b question and thank you very much for your help
  2. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,277Coins
    When I looked earlier with you, there was telemetry for all ship movement.(in the tuning center)
  3. did2kan
    did2kan New Member Gold Contributor
    - 75Coins
    Thank for the new offset file, fast and great job. It's work with my 2DOF, I don't test with SRV
  4. splendiddd
    splendiddd Active Member
    CCTV security
    Netherlands
    812Coins
    I can confirm that the SRV works now with these values, even at the first try.
    Awesome work, thanks @Wagnard
  5. David s wan
    154Coins
    I can confirm the ship works for me as well, thanks alot for your work
  6. David s wan
    154Coins
    actually....run into another problem with SRV now....I notice the pitch on the SRV and ship is extra opposite of each other.....as in if your pitch is set correctly for ship, the SRV would be wrong....and if SRV is set correctly the ship will be extra opposite...
    also, is there a way to turn down SRV's telemetry feedback? SRV's feedback is extremely rough
    thanks
  7. splendiddd
    CCTV security
    Netherlands
    812Coins
    You can adjust the force and axis for the SRV in the xml.
    It is in the simtools plugin folder, for instance i have pitch at 40 and roll at 12 and reversed the pitch axis for the SRV.
  8. David s wan
    154Coins
    how do you do reverse? currently force is 100, do I just use -100?
    thanks
  9. Wagnard
    Wagnardsoft
    5,277Coins
    No,
    just change SRV_Pitch Reverse from FALSE to TRUE in the XML directly.
    Doing this reverse won't be necessary in the next plugin update. (soon)
  10. Wagnard
    Wagnardsoft
    5,277Coins
  11. David s wan
    154Coins
    how do I download it? it's saying download not avaliable
    usually I use the DOFreality plugin uploader but I don't believe it was updated yet
  12. Wagnard
    Wagnardsoft
    5,277Coins
    This message happens when you are not logged in usually.
  13. kermitkong
    kermitkong Active Member Gold Contributor
    Hardware Development
    1,240Coins
  14. David s wan
    154Coins
    I'm logged in, that's the only way I can type message here anyway
    looks like it require me to sign up for the 1 year premium before it would let me download
  15. Wagnard
    Wagnardsoft
    5,277Coins
    Just edit the XML. set the force to "0" to the SRV movements
  16. kermitkong
    1,240Coins
    I tried exactly this, but no affect!
    Steps I made:
    -Downloaded the plugin (no offset file in the zip, Wonder !?!)
    -Downloaded offset file from thread
    -Put all via plugin updater to the directory
    -Patch the Game again
    -Start the game
    Could it be possible that the plugin is a compiled version ? Not the XML Version ?
    Best kermit
  17. Wagnard
    Wagnardsoft
    5,277Coins
    Patching the game extract the XML from the compiled version.
    So if you did modifications and patch after, you reverted theses modifications
  18. polybasss
    polybasss Member Gold Contributor
    Burgos Spain
    155Coins
    thanks for the new version of the plugin, once again
  19. kermitkong
    1,240Coins
    Thanks, it works !!!
  20. Benji85
    Benji85 Member Gold Contributor
    851Coins
    Anyone find the krait MK2 to have very little motion compared to the other ships such as python, fdl, asp to name a few?
