My platform with 2dof
Discussion in 'DIY Motion Simulator Projects' started by pablo ochoa, Apr 28, 2019.
  1. pablo ochoa
    pablo ochoa New Member
    176Coins
    IMG-20190427-WA0277.jpg IMG-20190427-WA0279.jpg IMG-20190427-WA0267.jpg IMG-20190425-WA0083.jpg IMG-20190427-WA0275.jpg IMG-20190424-WA0055.jpg IMG-20190427-WA0272.jpg IMG-20190427-WA0269.jpg IMG-20190427-WA0277.jpg Hi my name is Pablo Ochoa, I'm from Mina Clavero, province of Córdoba, Argentina ..
    I present my 2DOF project.
    After trying two different models of structure I tilt for the side to move the whole structure, with the engines ahead and move the entire platform.
    With the help of some friends who are here in the forum with similar projects I have managed to finish my project.
    It has two glass cleaner motors, Arduino Uno R3 board and a Monster Shield.
  2. Juanjo1986
    Juanjo1986 Member
    Comerciante.. Copiloto Rally...
    Argentina
    489Coins
    Hello Pablo, your project is very good ... continue to improve that simulator
  3. pablo ochoa
    176Coins
    many thanks friends
    I leave you a couple of more photos
    4f95a89d-7e91-4c23-bf83-668f24cb38c6.jpg 7be6b127-9895-4686-ad90-7e3b99c9daad.jpg 7ce09d20-6113-4f01-a8df-4871450af613.jpg 9f098360-c119-47a9-9f5d-32f497d8014a.jpg 13ea5bbc-90b3-4f24-999e-fa5a189f1f65.jpg 60ad4d9d-0723-4e93-839b-55236bf88b05.jpg 71bc4a0c-7c83-4c1c-9ff5-d46fafac3170.jpg 86ecf65b-6895-491b-b093-031df35893fe.jpg 5015c5d5-b319-4582-b0c5-3aa416f34355.jpg 8851e567-5e97-4b28-a155-73e6dc860026.jpg 87459237-2adc-4f67-a062-ecd3c64fcbf7.jpg a0d5f199-415f-4daf-993d-ba0c4f8edf44.jpg aad47866-b784-4cf6-9f07-35af35bdae7a.jpg abfb576f-2f82-4904-9593-e1a4cbeb57d2.jpg ef854d70-3049-45fe-9ce1-a9f97e8ba5e2.jpg
    to keep working on it and improve some things
  4. pablo ochoa
    176Coins
    First tests and a little calibration for the axes
  5. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    nice job but im confused by you saying the motors are GLASS CLEANER MOTORS ? where did you find them?
  6. pablo ochoa
    176Coins
    I mean clean buffalo brand windshield engines
  7. Tags..(VR)
    Tags..(VR) Member
    indiana
    - 6Coins
    i have a similar setup but one thing i wish i could and probably will is taking out the u joint for the pivot and replacing it with a 200 lbs compression spring to give heave . i think it would smooth the ride out a lot. ... that bottom framing. is that a 2" bed frame followed with 1" square bar on the top frame?
  8. pablo ochoa
    176Coins
    I think I should endure well. Use a 40x40 spout 1.2mm thick and support it well.
  9. pablo ochoa
    176Coins
  10. pablo ochoa
    176Coins
  11. jnikitas
    jnikitas New Member
    45Coins
    Que haces cordoba, como va?, te mueve bien con motores de limpia, yo tenia uno armado, ahora lo tire por mudanza, pero lo quiero hacer otra vez, y tenia los motores puestos atras, y la verdad que mis 90 kgs, no los movia alegremente
    153,009Coins
    +11,116 / 56 / -2
