Showroom Share my first SCN5 seat
Discussion in 'DIY Motion Simulator Projects' started by wp8051, Apr 30, 2019.
  1. wp8051
    wp8051 Racing simulator player Gold Contributor
    China
    224Coins
    AC motor, Motion platform, 4DOF
    I spent a week buying materials, then assembling and testing them, and the final result was perfect.
      90.2 KB
      473
      164.2 KB
      446
      81.1 KB
      471
      92 KB
      452
      166.1 KB
      445
      94.7 KB
      404
      144.7 KB
      431
      185.2 KB
      469
      144.7 KB
      478
      156.2 KB
      450
      152 KB
      453
      83.8 KB
      462
  2. wp8051
    China
    224Coins
    I used 2 rubber shock absorbers, which made the whole vibration and noise attenuate. I also installed 4 Fuma wheels at the bottom, which also have better shock absorption.
  3. wp8051
    China
    224Coins
    Because my home has less space, I can only make the bracket as small as possible. The size of the whole bracket is relatively small, the length is 660mm, the width is 600mm, and the height is 720mm.
  4. wp8051
    China
    224Coins
    Initially, I was a little worried. If I put the SCN5 in a relatively short position and make the distance of the putter shorter, would it not have enough power to push my body? My weight is 80KG, now tested. I think there should be no problem, the motion is still very good, and the noise is much smaller than my previous bracket. My previous brackets produced a lot of noise because it didn't choose the right damper.
