Bug Filter A axis suddenly stopped working.
Discussion in 'SimTools DIY Version' started by Trigen, May 10, 2019.
  1. Trigen
    Trigen Active Member
    2,891Coins
    Game Assetto corsa
    Main level does work
    A axis filters does not work
    B axis filters works
    Ive been tweaking filters all day and when i tweaked the A axis i forgot to save. I went back out and saw the setting were the same as when i left. I went back into the game and the filters no longer work regardless of setting, ive tested it many times with smoothing 5 50 100% etc. I have done a reinstall of Sim tools but no change. I have not wiped everything as i do not want to do all my profiles over again.
    Any tips?
    153,884Coins
    +11,154 / 57 / -2
    Can you please post pictures of all of your settings, including your Interface Settings.
  3. Trigen
    2,891Coins
    Here are the settings.
    Tested the other profiles i have and filters no longer work for any A axis
  4. Trigen
    2,891Coins
    I managed to get this working by doing a backup, removing all make a preset and using that + the backup. Maybe there was some file corruption or other issue.
    153,884Coins
    +11,154 / 57 / -2
    Great to hear you got it sorted, my best guess is that it was file corruption.
