Autmobilista 2 - Project cars engine
Discussion in 'Other Racing Games' started by Javo5, May 25, 2019.
  1. Javo5
    Javo5 Active Member
    Buenos Aires, Argentina
    300Coins
  2. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    We have a long wait for this until December :thinkwishing to try it ;)
  3. lysa elec
    lysa elec LYSA ELEC
    16Coins
    hello
    i dont find the pluging for last aumobilista
    153,710Coins
  5. bob williams
    bob williams OSW sfx100
    IT
    Ermelo, Netherlands
    113Coins
  6. bob williams
    IT
    Ermelo, Netherlands
    113Coins
    Today the beta version of ams 2 will become available for backers. Any chance the project cars plugin will work ?
  7. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    i will test once downloaded, release will be in 45mins:thumbs
  8. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    will also try fake pCARS2.exe if all else fails ;)
  9. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    no joy the system tab in the menu is greyed out so cant select the shared memory option :( just have to wait is all
  10. bob williams
    IT
    Ermelo, Netherlands
    113Coins
    Bummer.. so the waiting is for reiza? Or a new plugin?
  11. prodigy
    prodigy Burning revs
    Croatia
    6,698Coins
    Reiza to enable telemtry output.
  12. Zeraxx
    Zeraxx Member
    188Coins
    Its already enabled, in steam add the launch option "-ui:pcars" this will allow you to enable UDP and SharedMemory. Its using the exact same data output as PCars2 both for shared memory and UDP. The PCars2 UDP plugin works, I need to use the shared memory one because I have my computer also running telemetry so I need to keep the port open. But I think someone needs to make a plugin that looks for the AMS2.exe for shared memory, however the data structures is exactly the same.
  13. noorbeast
    153,710Coins
    That should be useful for @value1 in terms of creating a plugin, when he has some spare time.
  14. Zeraxx
    Zeraxx Member
    188Coins
    Yeah I should probably look at the documentation for making the plugins, and take a crack at it, I wrote my telemetry software all in C# but haven't done VB in quite some time.
  15. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    beat me 2 it lol
    however motion is working here with a fake pCARS2.exe all i did was copy the cmd.exe to desktop rename it pCARS2.exe the run it that gets simtools blue and ready for the data;)
  16. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    also once you have enabled shared memory in the system setting using the pcars ui you can then delete -ui: pcars (without space bloody emojis lol ) from the launch options in steam to return to the AMS2 ui
  17. value1
    14,236Coins
    Please give this plugin a try. I hope it works ;) I don't have βeta access.
    Please follow the instructions above (here and here).
    There is no MaxMin-file included. So you must set the MaxMin limits in TuningCenter!
  18. Zeraxx
    Zeraxx Member
    188Coins
    Will have to test once they allow UDP output again, they decided to turn off the workaround unfortunately last update. I will give it a go when they add it back in.
  19. Zeraxx
    Zeraxx Member
    188Coins
    Edit found a work around, to get data to output, @value1, the build you gave isn't detecting when the game starts, however following Dagurus advice did for the old plugin.
    Let me know what info you need and I can get it for you, looks like the memory file is still called the same thing it was in pcars2.
  20. value1
    14,236Coins
    Hmm, if the exe name of Automobilista2 is really "AMS2.exe" as mentioned above, SimTools should detect the start of Automobilista2 (when patched correctly). Can you confirm the exe name as in Windows Task Manager Details?
