My 6 DOF with ODrive
Discussion in 'DIY Motion Simulator Projects' started by Carelsbergh_Stijn, Jan 13, 2019.
  1. Carelsbergh_Stijn
    Carelsbergh_Stijn Member
    Belgium
    450Coins
    Hi, what firewall do you mean?
    Cheers
  2. Carelsbergh_Stijn
    Belgium
    450Coins
    So the output to the controllers in always a positive value?
    Cheers
  3. pmvcda
    15,702Coins
    yes
  4. yobuddy
    51,557Coins
    Press 'V' on the keyboard to get a view that's inside the car, then telemetry will flow as needed.
    Also, for more output information, please check out the appendices in the SimTools user manual.
    https://www.xsimulator.net/community/threads/official-simtools-user-manual.12424/
    Take care,
  5. Carelsbergh_Stijn
    Belgium
    450Coins
    Hi @pmvcda
    the output from FlyPT doesn't seem to be always positive, can I do something about this?
    Cheers
    Carelsbergh Stijn
  6. pmvcda
    15,702Coins
    I will take a look today.
    Edit:
    Yes, there's something missing...
    It's working for rotating actuators. Might have missed some crop on the linear ones.
    I'm correcting it... Should be a new version today.
    Edit#2:
    Where did you see the negative values?
    Was it in the interface? Because when you choose to see the output value on the serial, the value is not updated.
    The field uses the position in mm and that can be negative.
    It's an interface update error, because I use the same field (with another size) and just change the value.
    I will make a correction, but in the serial output it seems OK.
  7. Carelsbergh_Stijn
    Belgium
    450Coins
    Hello, I've reprogrammed my controllers to work with the negtive values (I saw them in the serial debug function) but I have another problem. When sending positions to my controllers with the command: p 0 <Axis1a><13> it works but there are two motors per controller so I need to send p 0 <Axis1a><13> p 1 <Axis6a><13> but this only seems to output to one of the actuators. How can I solve this? I've tried sending positions with 2 seperate outputs in the FlyPT interface but this doesn't seem to work because you can only connect with one command for each COM port.
    Thanks in advance
    Cheers
    Carelsbergh Stijn
  8. pmvcda
    15,702Coins
    Is it expecting value 0 and 1 or the char value of "0" and "1"?
    If it's 0 and 1, try: p <0> <Axis1a><13> p <1> <Axis6a><13>
    Because with that string you are sending the char value (look at the serial debug)
  9. Carelsbergh_Stijn
    Belgium
    450Coins
    Hi
    p stands for position, the 0 and 1 are for motor 0 or motor 1.
    My output is 'custom decimal', it doesn't seem to work, the ascii caracter 13 is 'end line' so it prints on the next line in the debug, I can't see it very well but I think it only sends oen 'p'.
    What can I do about this?
    Cheers
  10. Carelsbergh_Stijn
    Belgium
    450Coins
    Hi
    I found the problem, the space between the commands was not expected.
    I still can't get lfs to work properly, can you help me?
    Cheers
  11. pmvcda
    15,702Coins
    Are you in cockpit view? LFS outputs data, only in when we are in cockpit view.
    With Simtools or direct from the interface?
  12. pmvcda
    15,702Coins
    Here's a screenshot of my cfg.txt:
    Your file should also have around 215 lines and the darked area is what you should change.
    If the file is small, it's because you didn't complete a race yet. So go to the track and make a race of 1 or 2 laps to generate a complete cfg.txt
  13. Carelsbergh_Stijn
    Belgium
    450Coins
    Does this work in any gamemode you play?
  14. pmvcda
    15,702Coins
    Yes. Even replay (with cockpit view)
  15. Carelsbergh_Stijn
    Belgium
    450Coins
    It doesn't work, I've already deleted the file and let the game create a new one and it keeps saying: "trying to connect with LFS, but it's not sending data!"
    Anything else I can try?
    Cheers
  16. noorbeast
    153,986Coins
    +11,162 / 57 / -2
    Can I check if you ran a race in LFS in first person mode before patching it for motion, as that generates some required files.
    If not try un-patching, run a race and then re-patch.
  17. pmvcda
    15,702Coins
    Also, try to disable the firewall and test to see if it works.
    You might have to allow the application on the firewall.
    Can't remember anything more...
  18. Carelsbergh_Stijn
    Belgium
    450Coins
    Can it be something with the instalation folder where it is placed?
    Cheers
  19. pmvcda
    15,702Coins
    I don't think so, mine is in the second drive inside a folder and it's working.
    EDIT:
    Do you have another program using port 4123?
    Try running everything as Administrator.
  20. Carelsbergh_Stijn
    Belgium
    450Coins
    The administrator trick worked! Now, is it possible that the programme slowly moves back to the Original position because now, it kinda stays in the same postition.
    Cheers
