News MY PRINCESS
Discussion in 'DIY Motion Simulator Projects' started by Oms, Jun 15, 2019.
  1. Oms
    Oms known as "Doc6dof"
    France Colomiers
    - 177Coins
    DC motor, AC motor, Arduino, Motion platform
    Hello everybody,
    After having had fun with my first project ( a seat mover named Docxdof, cf post “Lauching finally a 3DOF (seat mover) instead 6DOF low cost dynamic simulator”,
    ) that allowed me to understand the different technical aspects, my new one will be MY_PRINCESS (as I have little time for work on this new project, that will take time, but it is also a great pleasure to develop such a project…).
    What does MY_PRINCESS mean:
    Maximum – Yaw – Pitch – Roll – Immersive – Nucleo_based - Compact – Enhanced - Sixdof – Simulator
    Why/how:
    Maximum-Yaw-Pitch-Roll:
    · by reducing distance between the cardans of the rig,
    · by increasing crank arm length (using gear motor with spring assistance + smart geometric bounderies control),
    Immersive:
    · by better realistic forces simulation (using washout algorithms with tilt coordination)
    · and probably VR
    Nucleo_based:
    · by using a STM32 board (compatible with Arduino IDE, I have already tested), much more power full because 32 bits instead 8, high quartz frequency, included a Floating Point Unit (I have also tested this board with a loop of floating cosinus -> 8000/s with my old arduino Uno3, 520000/s !! with the nucleo…)
    Compact:
    · by using rotary actuators instead linear,
    Enhanced:
    · enhanced pitch & roll for tilt coordination, etc
    Six_dof-Simulator...
    Consideration on actuators:
    Electric/hydraulic or pneumatic linear actuators are generally quite cumbersome (very long) so not really compatible with compact simulator. Moreover, with this kind of actuator you need to separate a lot cardans of the rig, so that limits a lot pitch/roll angles (so also surge&sway simulation by using washout algorithm with tilt coordination).
    The best compromise for me are electrical rotary actuators (powerfull, wide selection in voltage/rpm/power, less wear, more robust, easier to find, easy to customize torque/magnitude with more or less arm crank length, etc…), and if possible DC 220V (to suppress power supply and make easy the control, I think to develop in this case a triac command board).
    BUT it is more complex to design an hexapode with this kind of actuators (difficult to select the good dimension, geometry, to adjust bounderies, etc…) and I do not want to rebuild several time mechanics...
    SO the solution is to study the different solutions to find the best one, using a simulator of simulator ... For that I have developed an excel tool.
    Simulator of simulator tool:
    This tools will help me to finde the best geometry but also to make easy the development of the software on the nucleo board (I will just do portage from excel formula, the test with the same inputs if I obtain the same outputs... I have beginning and it is effectively a pleasure to write the soft and find the bugs...).
    Here after a demo:
    Drawing:
    I will do the drawings after having find the good geometry with the excel tool. But that wil look like that:
    So see you soon
    Great Scott !!!
    153,734Coins
    Sounds great, I am looking forward to following your build.
    The video will not play, perhaps the settings on YouTube are set to private rather than public.
  3. Oms
    France Colomiers
    - 177Coins
    Thanks... I have changed the rights with public, could you try again the video...
    153,734Coins
    Yep it works now :thumbs
