help needed
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Les Call, Jun 16, 2019.
  1. Les Call
    Les Call rotax 912
    retired
    81Coins
    Hi. Am going to try and build a 2DOF system and have bought a Monster Moto and a Arduino board but need to find a simple circuit /wiring diagram to get started can anybody point me in the right direction please.
    Les
    152,307Coins
    +11,070 / 56 / -2
    You have lots of Arduino code options: https://www.xsimulator.net/community/faq/arduino-code-for-use-with-various-hardware-and-simtools.31/
    But I would suggest you try SMC3, as the instructions are detailed and it has a app to do all the settings: http://www.xsimulator.net/community...3dof-motor-driver-and-windows-utilities.4957/
    If you are using cheap clone MMs then be aware of potential faults and how to test them: https://www.xsimulator.net/community/faq/reputable-monster-moto-suppliers-testing-before-use.158/
  3. Les Call
    Les Call rotax 912
    retired
    81Coins
    Hi thanks for the information wireing is now compleate one question how do you know the position of the pot on the motor shaft ? should it be fitted half way between travel furthest right and furthest left
    152,307Coins
    +11,070 / 56 / -2
  5. Les Call
    Les Call rotax 912
    retired
    81Coins
  6. Les Call
    Les Call rotax 912
    retired
    81Coins
    Hi noorbeast. Applied for a free DIY key but was denied ?as i thought i had done everything to qualify could you tell me why ? i dont have a problem buying the Key but i thought it was free to people that were building a DIY sim .Thanks Les.
    152,307Coins
    +11,070 / 56 / -2
    You must meet the criteria, which includes your build thread showing progress of the rig to the testing phase, please reapply once your build and thread meet that criteria:
    To qualify for a free license:
    • You must be building a true DIY motion simulator. (Not built from a kit or purchased from a simulator seller, a model simulator does not qualify.)
    • Have a unique build thread or Showcase in DIY Simulator Projects. (The thread should show some effort, which means it should show progress to the testing phase.)
    • Have been a member of the community for at least 30 days.
