I have problem with 2.1.02
Discussion in 'XSimulator Q&A/FAQs - Outdated' started by NathanAV, Jul 3, 2009.
  1. NathanAV
    NathanAV New Member
    0Coins
    I am finally find that problem causing me can not connect to force profiles ..it's look like conflicted with mmgdisplay , because mmgdisplay using com port and FTDI chip also..I have no problem without mmgdisplay attached..wuih...also a problem when restart xsim program with mmg display attached..Xsim wont detect SCN5..
  2. NathanAV
    NathanAV New Member
    0Coins
    :cheers:
    Thanks sirnoname for your effort for MMG plugin..
  3. ribban
    ribban New Member
    Sweden
    0Coins
    Hi
    Finally my x-sim rig is finished!! Had a few problems along the way but with help from you guys
    and a lot of thinking so are they just a memory. The actuators are there in the x-sim Profiler BUT ... i can´t start any game. I´m running -xsim21communityRC4-2103- on ONE computer. When i press data2 -it´s starting to send ,but Nothing happens.
    I have a qadro core cpu,windows xp 32-bits. What´s the starting procedure for this on a single computer? And what do you recommend for basic settings for the acuators?
    I have worked thru the whole FORUM for some hints that will work for my problem,i think.
    Thanks Michael
  4. ribban
    ribban New Member
    Sweden
    0Coins
    This test worked --------
    1. Insure SCN5 is detected and displayed
    2. Start the sender application and select the test plugin.
    3. let move the test slider 21 in auto mode
    4. press try connect button
    5. go to the math setup and insert a axis
    6. insert a gforce with effect 21 and automode
    7. now there must be drawn a sawtooth line
    8. go to ouput setup and to Synaptrix IO
    7. choose axis and a SCN5 as direct output
    BUT - whith a game nothing happens. Using a HEX adapter and RS232/usb.
    The test worked so the adapter must be ok. ? :?
    Regards Michael
  5. ribban
    ribban New Member
    Sweden
    0Coins
    yes. And now i getting error on comport 17 -message when i push the startbutton. Hardware problem?
    regards Michael
  6. ribban
    ribban New Member
    Sweden
    0Coins
    Ok. Thanks for reply.
    It´s problem with any game i try,the values are moving in to input .
    It´s seems to be no connection beetwen Profiler and Sender.
    I´m beging to think it´s a adapter problem. Using a HEXIN bought on ebay,halfduplex.
    Can Profiler detect the acuators even if the adapter is not right?
    I´m using only one adapter,are there any special setting in the software for that?
    The acuators calibrate when i start Profiler but thats it regarding to movement. Maybe you have a link to a shop who has a working adapter or adapter name?
    (I´ve spent the whole saturday and Sunday trying different things with this problem)
    Hardware issue instead ?
    regards Michael
  7. ribban
    ribban New Member
    Sweden
    0Coins
    i was looking in wrong section-there are no values in Input section only the text changes. I was looking in the Math-section. :blush:
    The rest info i will post tomorrow. Thanks for all the help.
    thanks Michael
      111.7 KB
      644
      118.1 KB
      612
  8. ribban
    ribban New Member
    Sweden
    0Coins
    I was planning to do screenshot-test tomorrow but im not so tired yet. :)
    I ran the testplug test. And that is working but not the games working.
    I´m sure I must have something in the Plug manual! But what.
    No comport error so far.
    rn2 file saved by the force profiler--where does that file goes,cant find it? In My Profiles ?
    Nothing there.
    I´m starting to feel pretty dum,but i´m 5 days new with this program.
    regards Michael
  9. ribban
    ribban New Member
    Sweden
    0Coins
    Thanks for the help. I will do that tonight when i get home.
    Regards Michael
  10. ribban
    ribban New Member
    Sweden
    0Coins
    Hi,sirnoname.
    Here is my rn2.file
    Thanks Michael
  11. ribban
    ribban New Member
    Sweden
    0Coins
    Interface.
    thanks Michael
  12. ribban
    ribban New Member
    Sweden
    0Coins
    This and no actuator moving.
    Thanks michael
  13. ribban
    ribban New Member
    Sweden
    0Coins
    Line change for RIGHT ACTUATOR in the Output Analyzer with LEFT ACTUATOR markt in the MATH SETUP ????
    thanks for helping me, Michael
  14. ribban
    ribban New Member
    Sweden
    0Coins
    I am SURE that i forgot some setting,but what. :(
    when i follow this video the actuators are moving. http://www.youtube.com/watch?v=L3qTJxwvE2c&feature=player_embedded#t=21
    But not when i put in the data myself see post above.
    Are there any special startingorder for Force Sender and Force Profiler and theres plugins?
    Like-- start Profiler first and choose plugin (+ mabye somthingmore) and then start Sender and choose plugin?
    Regards Michael
  15. ribban
    ribban New Member
    Sweden
    0Coins
    Good News!Thanks for all the help! :thbup: Tonight i will study the Manual very hard,i must have missed something.
    Regarding the line in Output Anyalyzer ,the line A2000439 Position Out moves up to the center in the diagram-box. I understand now that it should a jigsaw in there.
    Thank you very much again for all the help
    Michael
  16. ribban
    ribban New Member
    Sweden
    0Coins
    Hi!
    Just got it working!! :yippiee: Changed the settings in the SCN5 profiler like you suggested.
    Now it´s racingtime!
    MANY thanks to you sirnoname for tips and hints!! Priceless.
    Best regards Michael
  17. ribban
    ribban New Member
    Sweden
    0Coins
    This picture is taken while the actuators are running.
    Last adapter update has the value wandering beetwen 83 up to 91 outputs/persecond.
    Hope that is what you mean?
  18. ribban
    ribban New Member
    Sweden
    0Coins
    could even set switching time 0 and recieve delay 0.
    Safe as long there are no Output losses ?
    regards Michael
  19. ribban
    ribban New Member
    Sweden
    0Coins
    OK.
    thanks, Michael
  20. ribban
    ribban New Member
    Sweden
    0Coins
    Thanks for all info!
    With no checkboxes marked:
    1 , 1 , 100 = outputs/sec 143-167
    1 , 0 , 100 = outputs/sec 181-235
    0 , 1 , 100 = outputs/sec 135-166
    0 , 0 , 100 = outputs/sec 191-216
    Ran the test for about 3 minuts each, with no Losses at all. I´ll go for result--- 181-235?
    No changing of the switching timeout at this stage?
    Regards Michael
