  1. Fernando Romão Filho
    Fernando Romão Filho New Member Gold Contributor
    271Coins
    2DOF, AC motor, Arduino
    Good morning BlazinH, I'm sorry for the delay, I'm studying electrical engineering and I'm out of time, I finished my project, I'm going to send some photos of how it was, after they help me post it on the forum, thanks for all the help
    Att
    Maicon Ruiz
  2. Claudemir
    33Coins
    Hi friend, thank you very much for your response!
    I'll check and try to correct my mutiny too.
  3. Claudemir
    33Coins
    Hello Friend ...
    I have been accompanying the wind project and I am very happy
    I just got the materials needed for my project.
    But I've read all the posts trying to figure out how to do it so I can have my project working.
    I use google translator and with my difficulty in programming and I noticed that they had modifications in the project over time and finally they arrived at an ideal configuration congratulations to all involved.
    But unfortunately I do not have the same ability and facility to understand how everything worked .....
    I would like if someone could do a summary so I can be making mine work as well.
    I put everything together like this in the post.
    simtools 2.0 pro
    1 Arduino R3
    1 MM
    2 inductors of 470uhy 6a
    2 fans 12v
    1 source 12v 30A
    But I'm not able to load the code for the arduino
    And besides that I have read and reread the post I could not even understand which line should I change for PWM. work with Iracing etc.
    Please can i take a step by step how to make my ventop simulator work?
    I'm not lazy and it was actually read the full post because my lack of programming knowledge affects my learning!
    I will be very grateful to you.
    And this will help many users just like me.
    Thank you!
    151,467Coins
    +11,039 / 56 / -2
    Please be aware that you can dual language post but must provide an English translation, as per the Forum Rules, using Google Translate is fine: https://www.xsimulator.net/community/threads/forum-rules.9527/
  5. Claudemir
    33Coins
    Hi friend, thanks for alerting me! sorry
    When I downloaded my translation, I translated it automatically and I did not understand it!
  6. Claudemir
    33Coins
    hello friends, I've come to show you how my wind simulator got to you! If someone wants to use my box made in 3d printer just talk to me that I make the file available! This box is for the arduino with 80mm cooler. I made it personalized with my logo. But I can withdraw if that is the case. I also want to thank the @SilentChill for having made available the Arduino code that made it very easy for me! And to all involved in this wonderful project.
    upload_2019-5-11_11-41-6.png upload_2019-5-11_11-41-49.png upload_2019-5-11_11-41-30.png
    • Winner Winner x 3
  7. SilentChill
    20,586Coins
    Nice job looks great :)
  8. Grzegorz1975
    Grzegorz1975 New Member
    52Coins
    Hi Guys. I love the project ,that way I decide to build it and add to my rig.Its second arduino uno I brick/damage? After upload the sketch to the uno and power up software and the game it works for 10 minutes and stop working . When I checked the green led on is not on anymore. I try to upload sketch again , separate monster moto from arduino and got the message "
    avrdude: stk500_recv(): programmer is not responding
    avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xdb
    I try to reset arduino but nothing working??
    This is my second uno ,one from ebay,one from jaycar (local store)
    Any sugestion guys ,is it chance monster moto is faulty and damage urduino or do I do something wrong.
    Everything worked fine for few minutes so I belive all cables are solder ok , no any burn smell ,is just stop working
  9. paulopsx2
    paulopsx2 Active Member
    brasil
    647Coins
    Well, you are using inductors like original POST sugest?
  10. Grzegorz1975
    52Coins
    Yes ,I have four inductors the same spec.
  11. paulopsx2
    brasil
    647Coins
    What font are you using?
  12. paulopsx2
    brasil
    647Coins
    here besides having put the heatsinks on top of the MM chip I also put a 12mm fan on top
  13. Grzegorz1975
    52Coins
    I'm not sure what you mean?
  14. Grzegorz1975
    52Coins
    I didn't use fan or/and heat sinks. Is that means my monster moto overheating? What about Arduino ,is it damage because I didn't have heat sink and fan?
  15. Grzegorz1975
    52Coins
    I
    I have the same type power supply. Is it possible that it couse the problem with Arduino? I saw the sets for sell pre assembled and similar power supply like the one we have. Doas anyone use led power supply with success for our project?
  16. Grzegorz1975
    52Coins
    Hi can you please send me a STL file for the box . Thank you
  17. Harm van der Werf
    Harm van der Werf New Member
    125Coins
    Hey guys,
    I'm trying to set up everything but after having bought a lot of parts the Seaflo doesn't run constantly like the following video demonstrates:
    I've bought the following adapter (12V, 6A):
    https://www.ebay.com/itm/AC110-220V...var=571173310725&_trksid=p2057872.m2749.l2649
    Even when I connect the Seaflo directly to this power adapter it gives me the same issue.
    I'm not that advanced with electronics in this way, so what am I doing wrong? How can I make sure power source can handle the Seaflow?
    Thanks in advance!
    Harm
  18. Grzegorz1975
    52Coins
    You don't have enaugh power. You should buy bigger power supply 20A 12v at least.
    One seaflo can drain 6 A so the ps you got is good enaugh for one fan only
  19. Harm van der Werf
    125Coins
    Thanks for the reply. I guess I forgot to mention that the video is not from me, but I'm simply experiencing the same issue. I have just one Seaflo, so it should be enough theoretically, but if I understand you correctly, having a bit more amps is not a bad idea, right?
  20. Grzegorz1975
    52Coins
    You can connect 12v 30A PS as will be fine. But if is not enough power you will have trouble
