Codemasters F1 2019 plugin v2.0.1
SimTools plugin for Codemasters F1 2019
  1. yobuddy
    51,196Coins
    yobuddy submitted a new resource:
    Codemasters F1 2019 plugin - SimTools plugin for Codemasters F1 2019
    • Like Like x 8
  2. Djules
    Djules New Member
    - 175Coins
    DC motor, Arduino, 4DOF
    good thank you !!!
    I will try this :D
  3. Giorgio73
    Giorgio73 Alluminium rig with prosimu 3dof kit
    Plc enginer
    Italy,Varese
    822Coins
    2DOF, SCN6
    Hello yobuddy
    this plugin work with simtools 2.3.1 or is necessary the last version?
    Thanks in advance
  4. Andreawrc83
    Andreawrc83 Andywrc Gold Contributor
    commerciante
    italia
    73Coins
    I tried, but it doesn't work. ho f1 2019 steam directx 12 and a workstation 2 dof. what can I do
  5. Andreawrc83
    commerciante
    italia
    73Coins
    I've patch the game correct, in .../my games/f1 2019. Game managere is green!
    But in game don't go...
  6. DE CASTRO
    DE CASTRO Gaby SimAxe Beta Tester Gold Contributor
    Cahors France
    621Coins
    2DOF, 3DOF
    The plugin runs live 11 but if we launch the game live 12 Game Engine and Game Manager does not turn blue.
    Le plugin fonctionne en direct 11 mais si on lance le jeux en direct 12 Game Engine et Game Manager ne passe pas au bleu.
  7. Andreawrc83
    commerciante
    italia
    73Coins
  8. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, the plugin works in dx12 or in dx11 thanks
  9. DE CASTRO
    Cahors France
    621Coins
    2DOF, 3DOF
    With me works with direct 11 but not with direct 12
    Avec moi fonctionne avec direct 11 mais pas avec direct 12
    • Dislike Dislike x 1
  10. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    The plugin works for me in DX11 UDP legacy mode.
  11. Pascal TALAVERA
    Pascal TALAVERA New Member
    149Coins
    Bonjour, simtools ne detect meme pas que je lance le jeu. une idee ?
  12. yobuddy
    51,196Coins
  13. Pascal TALAVERA
    149Coins
    quand je lance simtools . il ne detecte pas f1 2019. donc rien ne fonctionne
  14. DoubleM
    Amsterdam
    - 23Coins
    Try these settings.
  15. Jeroen Vrancken
    Jeroen Vrancken ProSIMU T3000 Gold Contributor
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    The plug-in only runs in dx 11 legacy mode. So starting the game in dx 12 mode, will result in no motion.
  16. noorbeast
    152,553Coins
    +11,087 / 56 / -2
    Please be aware that you can dual language post, but an English translation is required, as per the forum rules: https://www.xsimulator.net/community/threads/forum-rules.9527/
  17. bruno1210
    bruno1210 schumi06
    103Coins
    pity because the dx12 version works really much much faster thank you for the info
  18. Andreawrc83
    commerciante
    italia
    73Coins
    For me go if i set "Udp brodcast mode ON", but so my dashboard don't go. I wait the ultimate plugin, thanks....
  19. Pascal TALAVERA
    149Coins
    [QUOTE = "DoubleM ext 181777, member: 28544"] Try these settings.
    [Attach = full] 63943 [/ attach]
    [Attach = full] 63944 [/ attach] [/ QUOTE]
    everything is ok works with DX 11.
    thank you so much
  20. Wiseman1
    Wiseman1 New Member Gold Contributor
    Netherlands
    - 56Coins
    Thank you very much! Good job mate!:thumbs
