DIY FFB Steering wheel (MMosFFB ) (In Progress)
Discussion in 'DIY peripherals' started by Alexey, Dec 10, 2015.
  1. Sieben
    Sieben Active Member
    2,241Coins
    Cool))) Use 0.9. so guidances were uppon it) That's great )
  2. Danver
    Danver New Member
    117Coins
    DC motor, Arduino
    Awesome project!
    I'm wondering if the software works also with sensored bldc motor driver.
    Does it?
  3. BiT0
    BiT0 Member
    227Coins
    Do not think so
  4. Danver
    Danver New Member
    117Coins
    DC motor, Arduino
    Actually @Alexey put some image on wiring a BLDC controller in the first pages of this thread, but I don't know how it ended up...
    I wanted to build my own ffb wheel base with a 400w BLDC motor. With some gearing, I calculated a nominal torque of 7.5Nm at 1000 rpm at the wheel. The peak torque should be definitely higher. Basically I was looking to build something more or less powerful as a Fanatec Clubsport v2.5, but definitely cheaper. Currently with some cost estimation, I can get controller, driver, motor and PSU for 160-180€, which compared with a 549€ wheel base it definitely cheaper...
    The only thing I need is the FFB software. I can make it on my own, but it will require me too much time to figure out FFB over USB interface and stuff like that. Thank you for your help!
  5. Danver
    Danver New Member
    117Coins
    DC motor, Arduino
    I just found out that the software for arduino was proposed by @auryza . I found in some video that it has more signal options for the controller (PWM+DIR, PWM+/-, ...) I was just wondering if it was supporting signals for BLDC. Does it?
  6. tomthomas21
    tomthomas21 New Member
    121Coins
    Hi! I build my own DIY wheel and pedals.
    Some information which found here in some comments was very useful. Thank you guys!
  7. tomthomas21
    121Coins
    Some picture about the assembled wheel and pedals.
  8. tomthomas21
    121Coins
    Sorry for the three post but I couldn't send a link before my third comment.
  9. Sieben
    2,241Coins
    tomthomas21, very nice!
    What's the device on the shaft?
  10. tomthomas21
    121Coins
    Thank you!
    I didn't want to use a cable to the buttons on the steering wheel. So I built a sliping rings for the connection between the arduino and the buttons. I used a hollow shaft, the cables there are in it.
  11. Sieben
    2,241Coins
    Very cool solution!
  12. Danver
    Danver New Member
    117Coins
    DC motor, Arduino
    Nice build @tomthomas21 !
    What motor are you using? It seems quite fast!
  13. tomthomas21
    121Coins
    Thank you!
    I used a Denso 45200 05271 power steering servo motor from a Toyota with 4:1 ratio. I measured 14 Nm on the steering wheel with 67% performance (power supply: 12V 480W).
  14. Danver
    Danver New Member
    117Coins
    DC motor, Arduino
    I forgot to ask, which is the output power of the motor? And what you mean for 67% performance?
  15. Sieben
    2,241Coins
    tomthomas21, could you give the name of the pulleys with a belt please.
  16. tomthomas21
    121Coins
    I dont know the motor output power, so I wrote the torque. The main gain can be controlle from the software, so with 67% setting I measured 14 Nm torque on the steering wheel.
  17. tomthomas21
    121Coins
    I used HTD-5M timing belt with 60 and 15 teeth pulleys.
  18. wannabeaflyer2
    london uk
    8,339Coins
    Hi guys , Just finished 1st stage build of my Reduction drive FFB wheel and Wow @tomthomas21 just seen you rig , that is some nice engineering and loved the slip rings idea , thanks for posting .. just wanted to add thanks fo @Sieben for the info that go me on this journey , attached ia my 1st attempt at proper Build , but already im thinking I need 4:1 instead of my 3.25 :1 .
    notice you guys seem ok with putting electronics inside the wheel housing , I thought vibration might have been an issue so I had mine in separate housing .. Trying to put togather and assembly slide show an will post it on youtube once done .. also will start my own build thread , but as mentioned ....big thanks guys for the inspiration and all the help .
  19. Sieben
    2,241Coins
    wannabeaflyer2 Wow, that's a very nice tiny housing! Thank you pal for kind words! ;)
  20. wannabeaflyer2
    london uk
    8,339Coins
    Cheers @Sieben once its all finished i'll put cad drawing on My new Post , took load of photos but don't want to overload the forum LOL so U tube slide show may save the day LOL ..
    one last techie question ... when I do wheel check and select spring test , it feels great in one direction but notchy and judders in the opposite direction . can any one say what likely to be happening here Cheers
