6 axes of movement
Discussion in 'New users start here - FAQ' started by Ivan Zaharov, Jul 6, 2019.
  1. Ivan Zaharov
    Ivan Zaharov Member Gold Contributor
    Industrial repair CNC
    Latvija
    219Coins
    2DOF, AC motor, Arduino, Motion platform, 6DOF
    Hello. I want to make a simulator with a moving system, using all 6 coordinates of movement on the simulator ASSETO CORSA. Equipment available, desirable and professional experience in electronics, metal processing, automation. Express your opinion about my desire. .
    153,920Coins
    +11,156 / 57 / -2
    A 6DOF is an ambitious first project, so spend some time researching.
    You will find plenty in the FAQs to get your started: https://www.xsimulator.net/community/faq/
    Including a 6DOF section: https://www.xsimulator.net/community/faq/6dof.22/category
    There is a glossary for all those acronyms we tend to use, which will help you decipher some descriptions: http://www.xsimulator.net/community/faq/glossary-of-acronyms-and-names.66/
    Feel free to ask questions on your build thread, the members here give freely of both their time and expertise.
    Good luck with your project.
  3. Thanos
    Electronics Engineer
    2,907Coins
    Plan to use linear servomotors?
    Something like this?
  4. Ivan Zaharov
    Latvija
    219Coins
    Hello. No, the system will be different. One drive, one axle. Rotate the chair radius of 1 meter 360 degrees. chair tilt + - 90 degrees, tilt forward and backward 45 degrees (90 like, but this greatly increases the size of the structure). Two more axes are linear (forward, backward) (left, right). Another axis, this is a platform up and down (I think it will be enough + - 200 mm) Something like that.
  5. Ivan Zaharov
    Latvija
    219Coins
    Since I was engaged in repairing industrial CNC machine tools, I had the idea to make a chair for an industrial robot, then you fly in all the poems.
    153,920Coins
    +11,156 / 57 / -2
    Could you please draw a picture of what design you have in mind.
  7. Ivan Zaharov
    Latvija
    219Coins
  8. Thanos
    2,907Coins
  9. Thanos
    2,907Coins
  10. Ivan Zaharov
    Latvija
    219Coins
    Sory.
    Hello. I read a lot of information and decide to make a 4DOF simulator for starters. And the AC drive so far I have
    only 4dof. I want to control the step / dir signals.
  11. Snipe3000
    Snipe3000 New Member
    Software Engineer
    San Diego, CA
    272Coins
    2DOF, DC motor, SCN6
    Wouldn't it be very difficult to be stronger than a simcraft rig, cause its center of mass is balanced inside the cage?
  12. Ivan Zaharov
    Latvija
    219Coins
    Thanks for the answer. I'm confused, don’t know what to do. I wanted to do on such a principle (https://www.motion-sim.cz/new/?page=home&article=15&menu=79), but my friend went on this, and he did not like it. Can I do 6 DOF? How much is 6DOF better than others? I will have actuators with a stroke of 450 mm.
  13. Ivan Zaharov
    Latvija
    219Coins
    Good day. I reviewed a lot of information, I decided to do it on your controller. Actuators are almost ready for me. Servo control step / dir. I understand that I need AMC-AASD15A.
  14. Thanos
    2,907Coins
    Yes, but the controller is out of stock right now until I get more parts. It was sold out because of Black Friday/Cyber Monday sale...
    https://www.tindie.com/products/tronicgr/amc-aasd15a-servo-motion-controller/
    Make sure to use AASD-15A servos with it to be plug and play with ready DB25 male-male cables... You don't want to experiment with other servos and custom cables... :eek:
    Unless you wanted buy actuators from PT-Actuator supplier, he also sells the AMC-AASD15A controller along his actuators kit...
    Thanos
  15. Ivan Zaharov
    Latvija
    219Coins
    Hello Tanos. It makes no sense for me to take the kit from the PT-Actuator, since cam motors and drivers have already been purchased. I am a professional electronics engineer, I have no connection problems. At the same time, I work on the repair of industrial CNC machines. I have a GS-AS15BF servo driver. I can assemble your block myself, I have everything for this. What about the firmware code? I am ready to pay for your service.
    Best regards
    Ivan.
    Latvija
  16. Thanos
    2,907Coins
    Hi Ivan,
    Do you have manual of the GS-AS15BF driver? I wanted to see if it supports Torque reach signal output that is needed for the automatic calibration...
    *Edit
    Is it this one?
    https://www.rgbautomatyka.pl/gb/p/f...a4e960ff2e/SG-AS-SERVO-DRIVER-USER-MANUAL.pdf
  17. Ivan Zaharov
    Latvija
    219Coins
  18. Thanos
    2,907Coins
    Do you have a manual for it? The one in the link looks incomplete. It doesn't show the parameters to set the functions for the output pins or torque related parameters...
  19. Ivan Zaharov
    Latvija
    219Coins
    Large file, 17 meg. Where can I drop it?
  20. Thanos
    2,907Coins
    Maybe use dropbox? They offer free storage...
    Use this link to register: https://db.tt/cLPbL2yy
    Thanos
