Codemasters F1 2019 plugin v2.0.1
SimTools plugin for Codemasters F1 2019
  1. Daniel_83
    Daniel_83 New Member
    Poland
    223Coins
    Ok, now it works, the problem was that I use simtools and simhub, both are on the same port.
    But now, I do not know what to do to make it work 3dof and bass shakers.
    If I change the port for sumhub and add the line in hardware_settings_config, after starting the game my line with simhub port will be removed automatically.
    Any ideas ?
    Hi, I try settings like at screens few post above, at my Dofreality p3 but it doesn't work :/
    Did somebody manage to run dofeality p3 with F1 2019?
    151,461Coins
    +11,038 / 56 / -2
    Try this: https://www.xsimulator.net/communit...imhub-dashboard-no-working.11017/#post-169164
  3. Daniel_83
    Poland
    223Coins
    It does not work, I wrote it with my firts post, I add new line at hardware_settings_config, and when I start the game my new line (UDP2) be removed automatically from hardware_settings_config.
    At game settings we can add only one port, I think it is the problem. Game can't read two diffrent port.
    At other codemasters game, like dirt, dirt rally 2 etc, everything work fine, I add UDP1 for simtolls, UDP2 for simhub and it works, but at F1 2019 it does't work.
  4. DoubleM
    DoubleM Member Gold Contributor
    Amsterdam
    - 23Coins
    Normally you can use this setup. But now it doesn't work because of the legacy mode of the simtools plugin.
  5. Asim Chohan
    Asim Chohan New Member
    55Coins
    hi, i use DOF P3 and i also having problems due to port conflict. I use simtools and simvibe. After struggling for days trying to get to work together, trying to use Codemasters Proxy server (doesnt work for f1 2019 but ok with f1 2017), i ended up downloading Game Vibe for simtools and got engine sounds and gearshifts almost as good as simvibe, although a lot of trial and error getting the right feeling.
  6. Jeroen Vrancken
    Jeroen Vrancken ProSIMU T3000 Gold Contributor
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    My motion worked, after the 1.05 version the plugin stopped working. I als noted that in the telemitry menu the is an extra option (restriced and public)
    Any one else having the same problem, motion stopped to work in 1,05 patch???
  7. DoubleM
    Amsterdam
    - 23Coins
    It is still working. Don't forget to start it in DX11
  8. Jeroen Vrancken
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    The problem was that Udp was on, the plug-in is fine!
  9. bruno1210
    bruno1210 schumi06
    103Coins
    hello, I can not operate the telemetry of the games damage a good update .
  10. yobuddy
    50,743Coins
    I don't understand, sorry buddy.
    Take care,
  11. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, can not run at the same time simtools and simhub on f1 2019 not dx12 also we must wait for an update thank you.
  12. Jeroen Vrancken
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    Plug-in only works with dx 11 at the moment. With respect to sim hub, using sim hub requires to activate the udp relay and most importantly to have 2019 output working (this is not the case with the current plugin).
  13. Jeroen Vrancken
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    Is the plugin still progressing? The plugin only working in DX11 is fine for me, but i would love to see the 2019 format working, so i can use motion and simhub at the same time :)
  14. yobuddy
    50,743Coins
    That's the plan buddy, but my house goes on the market today and I have been so busy getting this place ready.
    Let's hope it goes quickly so I can go back to work lol.
    Take care,
  15. Jeroen Vrancken
    CPA
    Netherlands
    - 55Coins
    3DOF, SCN6
    All the best selling your house
  16. brubbs
    brubbs New Member
    138Coins
    Hi , i will try it on ps4 or someone did it and failed ?
  17. bruno1210
    bruno1210 schumi06
    103Coins
    Hello, I found a software to run simtools and simhub at the same time Sim Racing Proxy Server good guys.
  18. DoubleM
    Amsterdam
    - 23Coins
    Can you explain how? F12019 legacy mode and simhub F1 2019 ?
  19. bruno1210
    bruno1210 schumi06
    103Coins
    first you have to start configuring the game are the same settings as simtools except that you have to change 20777 by 20779.
    It is necessary to modify the port of simhub also origin 20777 by 20776, then to open the text file of simhub like the photos.
    To finish open Sim Racing Proxy Server as in the photo and always open simtools first.
  20. DoubleM
    Amsterdam
    - 23Coins
    Nice! I will test it. Thanks.
