Experimental DCS Plugin ready for testing
Discussion in 'Digital Combat Simulators (DCS)' started by Dirty, Jun 28, 2019.
  1. Dirty
    All the way up front.
    7,971Coins
    I'll take a look into it tomorrow.
    I'm sure we will get it to work :)
    Dirty
  2. Dirty
    7,971Coins
    Can you check if you have this...
    -- Experimental Export plugin for SimTools V2.3 (created by Value1, modified by Dirty)
    -- Version 0.03
    Myfunction =
    Start=function(self)
    package.path = package.path..";.\\LuaSocket\\?.lua"
    package.cpath = package.cpath..";.\\LuaSocket\\?.dll"
    socket = require("socket")
    my_init = socket.protect(function()
    -- export telemetry to SimTools
    host1 = host1 or "127.0.0.1"
    port1 = port1 or 41230
    c = socket.udp ( )
    c:settimeout ( 0 )
    c:setpeername ( host1, port1 )
    end)
    my_init()
    end,
    AfterNextFrame=function(self)
    --Euler Angles
    local mySelf = LoGetSelfData()
    local Yaw = mySelf.Heading
    local Pitch = mySelf.Pitch
    local Bank = mySelf.Bank
    local accel = LoGetAccelerationUnits()
    local omega = LoGetAngularVelocity()
    --Air Data
    local IAS = LoGetIndicatedAirSpeed()
    local AOA = LoGetAngleOfAttack();
    --Weight On Wheels
    local LeftGear = LoGetAircraftDrawArgumentValue(6)
    local NoseGear = LoGetAircraftDrawArgumentValue(1)
    local RightGear = LoGetAircraftDrawArgumentValue(4)
    local WOW = 0 --WOW = Weight On Wheels
    if (LeftGear > 0 or NoseGear > 0 or RightGear > 0)
    then
    WOW = 1
    else
    WOW = 0
    end
    --change exported values when on ground
    if (WOW == 1) then
    accel.x = accel.x * 1.00
    accel.y = accel.y * 1.00
    accel.z = accel.z * 1.00
    end
    --send data via UDP
    my_send = socket.protect(function()
    if c then
    socket.try(c:send(string.format("%.4f; %.4f; %.4f; %.4f; %.4f; %.4f; %.4f; %.4f; %.4f;\n", omega.x, omega.y, omega.z, accel.x, accel.y, accel.z, WOW,IAS,AOA)))
    end
    end)
    my_send()
    end,
    Stop=function(self)
    my_close = socket.protect(function()
    if c then
    c:close()
    end
    end)
    my_close()
    end
    -- Overload
    -- Works once just before mission start.
    do
    local PrevLuaExportStart=LuaExportStart
    LuaExportStart=function()
    Myfunction:Start()
    if PrevLuaExportStart then
    PrevLuaExportStart()
    end
    end
    end
    -- Works just after every simulation frame.
    do
    local PrevLuaExportAfterNextFrame=LuaExportAfterNextFrame
    LuaExportAfterNextFrame=function()
    Myfunction:AfterNextFrame()
    if PrevLuaExportAfterNextFrame then
    PrevLuaExportAfterNextFrame()
    end
    end
    end
    -- Works once just after mission stop.
    do
    local PrevLuaExportStop=LuaExportStop
    LuaExportStop=function()
    Myfunction:Stop()
    if PrevLuaExportStop then
    PrevLuaExportStop()
    end
    end
    end
    ...code in your Export.lua file? You should find it in C:\Users\[your name]\Saved Games\DCS\Scripts\Export.lua
    And can you also check if version 0.02 works? link here
  3. gbdesai
    gbdesai New Member Gold Contributor
    84Coins
    I'll check first thing in the morning. Not home right now. Thanks for working on this! Also quick question. For the normal plugin I used the anti-roll option along with smoothness, washout and gain.
    Do I need to get rid of those advanced settings when I get this plugin working?
    G
  4. Dirty
    7,971Coins
    As far as I know, the anti-roll function is obsolete with this experimental plugin. After all it is the very reason I did this modification.
    The smoothing/washout should still be applied. Exactly which filter depends on whether you use SimTools or FlyPT. In the latter I'd use a LP(HP) on Roll and Pitch.
    Dirty :)
  5. Dirty
    7,971Coins
    Btw, is anyone else having trouble with v0.03?
  6. Trip Rodriguez
    Trip Rodriguez VR Pilot
    Lake Ariel, Pennsylvania
    3,978Coins
    Didn't get to test, last night turned into a total Cluster____. Computer kept locking up, files getting corrupted...... something I've been using has been causing problems, either that or the old Samsung 840 Evo Windows is installed on might finally be going bad.
    Found out one thing that cost me hours last night was one of the zip ties holding down my motion compensation wand was depressing the grip button.... 30 second fix after hours of troubleshooting.... argh.
    Finally got everything straightened out just in time to get ready for bed. Hopefully I'll be able to do some testing tonight or tomorrow but I have family obligations the next few days so no guarantees.
  7. Moe Colontonio
    Moe Colontonio Member Gold Contributor
    New Jersey USA
    825Coins
    I'll give this a try today. Not sure how much help I can be, I'm clueless with how the software interfaces with my motion rig. I'm currently using a prosimu T1000 3DOF with simtools pro. I was using a modified export.lua to smooth out the loop effect, and was never able to get any yaw working for DCS. I'll check back later, thank you for the effort!
    I fly the AV8 exclusively
  8. Moe Colontonio
    New Jersey USA
    825Coins
    So I installed the plugin and patched it after removing the old patch. I'm getting a violent roll reversal in rolls, and about 3/4 of the way through a loop. Still no yaw.
    This is in the AV8 with a prosimu T1000 3 DOF
    Contents of my export.lua:
    -- Export plugin for SimTools V3
    -- Version 1.0
    -- Export start
    Myfunction =
    c = socket.udp ( )
    c:settimeout ( 0 )
    -- c:send ( "Hello Wolrd!" )
    -- c1 = socket.try(socket.connect(host1, port1)) -- connect to the listener socket
    -- c1:setoption("tcp-nodelay",true) -- set immediate transmission mode
    -- c1:settimeout(.01)
    end)
    my_init()
    end,
    local altRad = LoGetAltitudeAboveGroundLevel()
    local pitch, bank, yaw = LoGetADIPitchBankYaw()
    -- reduce forces on ground
    -- if altRad < 3 then
    -- accel.x = accel.x * 0.25
    -- accel.y = accel.y * 0.25
    -- accel.z = accel.z * 0.25
    -- end
    if c then
    -- socket.try(c1:send(string.format("%.3f; %.3f; %.3f; %.3f; %.3f; %.3f;\n", pitch*1000.0, bank*1000.0, yaw*1000.0, accel.x*1000.0, accel.y*1000.0, accel.z*1000.0)))
    socket.try(c:send(string.format("%.4f; %.4f; %.4f; %.4f; %.4f; %.4f;\n", pitch, bank, yaw, accel.x, accel.y, accel.z)))
    end
    end)
    my_send()
    end,
    Stop=function(self)
    if c then
    c:close()
    end
    end)
    my_close()
    end
    -- Overload
    do
    Myfunction:Start()
    end
    end
    end
    do
    end
    end
    end
    do
    Myfunction:Stop()
    PrevLuaExportStop()
    end
    end
    end
    local SimShakerlfs=require('lfs'); dofile(SimShakerlfs.writedir()..'Scripts/SimShaker.lua')
    dofile(lfs.writedir()..[[Scripts\SimShaker-export-core\ExportCore.lua]])
      197.5 KB
      739
      205.9 KB
      613
  9. Dirty
    7,971Coins
    That's the old (conventional) Export.lua! Download v0.03 (first post), unpatch the game and then repatch with the latest plugin.
    Tell me how it went, I'm happy to help anytime and I'm curious to know why things go wrong sometimes :)
    Dirty :)
  10. Moe Colontonio
    New Jersey USA
    825Coins
    Thank you for the reply. So I'm closing Game Manager and Engine after unpatching. Opening Plugin Updater and adding v.03 and it adds sucessfully. Open Game Manager and patch, select directory, and it keeps patching to the old version. I even deleted export.lua completely and it still creates a new one with the old version. What am I missing here?
  11. Moe Colontonio
    New Jersey USA
    825Coins
    After some messing around, I'm having the same trouble as gbdesai. Removed everything related to the old plugin, tried re-installing the v.03 plugin several times. Get a message asking if the plugin was installed incorrectly. No DCS plugin showing in game manager list. Old plugin installs just fine. Simtools 2.4.0 pro.
  12. Moe Colontonio
    New Jersey USA
    825Coins
    Ok I manually applied the plugin, by unzipping the .dl file to my plugins directory and putting the export.lua into my saved games/dcs/scripts. It works! In the air, the AV8 feels amazing, much better than the old plugin and I have yaw! I air started for the test, and on landing got some really crazy shaking and yawing, even after stopping completely. Any ideas for fixing that? I'd also like to increase the yaw effect. Export.lua and simtools setting below.
    This will be much better for helicopters and such, it is so much better than the old plugin when in the hover. Thank you again for the effort.
      214.3 KB
      621
      210.3 KB
      636
      204.6 KB
      648
      170.3 KB
      619
  13. Moe Colontonio
    New Jersey USA
    825Coins
    Ok all sorted! The ground multipliers in the default export were *1000! Dropped them to 1, and it's running perfectly. Seriously guys I can't thank you enough!
  14. Dirty
    7,971Coins
    Thank you! That's great to hear.
  15. Dirty
    7,971Coins
    Yes, that was it! I was just about to write this to you when I got your post. :grin:grin
    I did this *1000 factor to check if the OnGround detection worked properly and to see if the gain was applied properly. Guess I didn't remove it before compiling the plugin and it found it's way into v0.03 :blush
    I will correct it before the weekend. As a quick fix you can manually change those values back to "1.0" like @Moe Colontonio did.
  16. Dirty
    7,971Coins
    I will try to find out why some people have trouble installing it. Or why the previous plugins Export.lua file keeps re-appearing.
    @value1 , somewhere in the plugin code it said: "Name of plugin, must be unique". Could it be that it causes an unresolvable ambiguity between the original plugin and my modification if I don't rename this?
    Dirty :)
  17. value1
    14,240Coins
    @yobuddy Can you clarify this? (Private Const _GameName As String = "DCS" 'GameName (Must Be Unique!) - the displayed Name.)
  18. Dirty
    7,971Coins
    OK, I gave it a try to simply rename the plugin without really knowing what it would do internally :)
    Initially, I got a few errors, but I think I was able to fix them manually.
    You can download v0.04 here.
    The plugin should now show as "DCSx" (x for eXperimental) in SimTools and I'm hoping that this will lead to the plugin no longer interfering with the original plugin. We'll see... :) Let me know if it still does, and also if you run into other issues.
    Dirty :)
  19. Dirty
    7,971Coins
    It seems, when I install this plugin AFTER the original plugin, SimTools will show two plugins in the list in GameManager. Unfortunately BOTH are now named "DCSx" :confused: but in the file location (C:/Users/[YourName]/AppData/Local/SimTools/GamePlugins) it only has the plugin installed last
    I was hoping for people to be able to have both selectable, but as of now, I would not recommend doing that. Maybe there is a way, but I wouldn't know how to do that.
    Until then, my recommendation is to...
    1. Remove original patch in GameManager
    2. Check C:/Users/[YourName]/AppData/Local/SimTools/GamePlugins to be sure there is no DCS_GamePlugin.dll
    3. Open PluginUpdater and install the experimental DCS Plugin (DCSx)
    4. Open GameManager and patch DCS for motion.
    Dirty:)
  20. gbdesai
    84Coins
    Oh wow, this sounds promising. I just got home from a business trip will be trying tonight. Maybe manual install of the DLL with the export.lua file will.fix the install issue.
