WANTED - Motor controllers in NZ or AUS
Discussion in 'Marketspace - Marktplatz' started by James Robbie, Jul 21, 2019.
  1. James Robbie
    James Robbie Active Member
    IT Specialist
    New Zealand
    538Coins
    I am in NZ and I am currently running a moto monstor arduino 2DOF set up (wiper motors). I am interested in trying the JRK boards as people seem to have more luck and consistent lasting results with them compared to the MM's.
    Looking 2nd hand local(ish) first in case I can save on $100 USD before shipping for new ones...
    I am open to other suggestions as well.
    Cheers
    153,710Coins
    Don't know how you will go getting second hand JRKs.
    Another alternative would be Sabertooth.
  3. James Robbie
    IT Specialist
    New Zealand
    538Coins
    Yip, happily discuss options around a Sabertooth as well!
    As an indication, to get brand new either 2 x JRK's or 1 x Sabertooth, its around $300NZD :( hence the optimism for something closer to home sitting in a cupboard or box :grin
    153,710Coins
  5. Gianni
    Gianni New Member
    Australia
    125Coins
    DC motor, 4DOF
    Hi James,
    What is the reason of failure?
    I have designed my own controller.. and using 4 individual Polulo.
    http://www.xsimulator.net/community/threads/micromite-3dof-controller.7370/
    You can build yourself also a good H-Bridge as attached.
    Good luck :thumbs
  6. James Robbie
    IT Specialist
    New Zealand
    538Coins
    153,710Coins
    the 32 can handle regenerative current with a suitable resistor, unlike the 60s which need a battery. The 32 would suit wiper motors, while the 60s can handle much larger motors, if you plan a future upgrade.
