_Gus's 6DOF Project
Discussion in 'DIY Motion Simulator Projects' started by _Gus, Jul 19, 2019.
Tags:
  1. SilentChill
    20,601Coins
    Nice work matey !
    Think you need to turn your levers 180 degrees they are in the wrong position, too upright
  2. SilentChill
    20,601Coins
    Also did you use M12 threaded bar for your rods ? They look thin
  3. _Gus
    _Gus Member
    406Coins
    Thanks for the suggestion! I turned them around and it is far more rigid than it was before (it was wobbling all over the place before). Here's the corrected setup:
    Yeah, they are pretty thin, and I'm working on fixing this. My plan right now is to slide some steel pipe over the rods to give them some extra material, and hopefully stop them from bending. If you push on them hard enough you can notice some deviation, even without any real load on there right now.
    Here's the link to where I bought the rods: https://www.mcmaster.com/6516k18
    Aside from the construction of the rig though, I'm having the same problem with SimTools again, and it's really putting a damper on any testing progress that I might be able to make. The issue is that when I reboot my computer, startup SimTools, and go to the output testing tab, everything seems to work for about a minute or two, but then SimTools seems to lose its connection to a motor pair (single Arduino) or even two pairs. I'm just not sure how to fix this, and restarting my computer every time this comes up doesn't seem like a good fix.
    Please if anyone has encountered this problem, or has any suggestions for me at all, let me know.
    153,764Coins
    +11,149 / 57 / -2
    That could be interference, like a faulty usb cable or needing better cable management and ferrite clips on cables.
    It could also be a computer band width issue.
  5. _Gus
    _Gus Member
    406Coins
    I don't think it's an issue with the cables. I have five in all and so far every single one of them has demonstrated this failure, and the odds of having 5 faulty cables are incredibly low.
    Could you elaborate more on this?
    153,764Coins
    +11,149 / 57 / -2
    While there are often many on-board motherboard USB ports on a computer they normally share controllers, so if you have too much demand on a given controller it will create a band width issue.
  7. _Gus
    _Gus Member
    406Coins
    Lets say I have 3 pairs of motors: pairs a, b, and c. Currently motor pair a is the one prone to failure, and won't run for long if the other pairs on plugged in. However, the other two pairs can run simultaneously, and so therefore would not, in this world, be on the same controller. This means that by testing a and b, or a and c, one of them should work since one must have two separate controllers.
    Unfortunately, I tried this, and it is not this case, which means it is extremely unlikely it's a bandwidth issue. Thanks for the suggestion though, it seemed totally reasonable that that could have been the issue!
  8. SilentChill
    20,601Coins
    How have you got the Ards connected ? If you havent I would suggest a powered USB 2.0 hub
    5/16ths is way to thin you would need at least 1/2 inch which would be similar to the M12 size,
  9. _Gus
    _Gus Member
    406Coins
    I have three six foot USB A/B cables which I have been plugging directly into my computer, since I have a bunch of free usb slots. The setup is identical between the three Arduinos., and 2/3 of them always work, even when I. swap the cables and or ports. This leads me to believe its the Arduino itself, and so I'm going to try and swap the Arduinos of the faulty pair with a working pair, and see if the problem moves with it. Hopefully it does, and I can just buy another Arduino and be done with the problem.
    Yes, I realize this now. Instead of buying thicker rods and having to buy new joints, and re-mill all of the plates the joints connect to, my plan is just to slide a steel pipe with a 3/8" ID and a 3/4" OD over the rods, which should give it plenty of strength.
  10. SeatTime
    You could try dropping the connection speed from 500000 to 115200. Either by earthing digital pin 8 on the Ard, or by changing the sketch (SMC3?). Some clone Ards can struggle at the 500000 speed.
  11. _Gus
    _Gus Member
    406Coins
    Thanks for the suggestion, SeatTime. I grounded pin 8, and set the baud rate to 115200 via SimTools, however that same motor pair still failed. I also tried increasing the output rate from 10ms to 50ms to see if that would make a difference, however it did not. This leads me to believe its not a bandwidth issue.
    I also went along and tried swapping an Arduino from one of the working motor pairs with the faulty pair, however the same issue occurred with the same motor pair, meaning it is very unlikely to be an Arduino problem. Also, because I just went and rewired it, I know its not an Arduino wiring issue. I'm honestly at a loss right now...
    Looking at the system as a whole, this is the setup:
    Power supply -->
    SimTools --> USB cables --> Arduino running SMC3 --> pin 13 wire --> Sabertooth 2x32 controller --> motors
    From the tests I've conducted so far, I believe I can safely rule out the problem being related to SimTools, the USB cables, the Arduino, and the Arduino wiring.
    This leaves the following components:
    • Power supply
    • Sabertooth 2x32
    • Motors
    I don't think it could possibly be the motors, as they have no computer or ability to change their function, and they consistently work with SMC3 Utils. This means that I think it has to be either the power supply, or the sabertooth controller. I'm not sure what tests to run to narrow it down between the two components, other than simply swapping the parts around, so I guess that's my next step...
    EDIT: in my psuedo-diagram, the psu is supposed to be connected to the sabertooth
  12. _Gus
    _Gus Member
    406Coins
    Quick update... I swapped the faulty sabertooth with a functional one, and it made no difference, ruling out the sabertooth as the problem component. I also don't think its the psu's, as they never cease to function when I'm running SMC3 Utils. I honestly don't know what to even try next.
    EDIT: I take it back. I cannot get SMC3 Utils to function with the faulty pair now. It still works with the other 2 pairs though... I'm going to try swapping the psus either tonight or tomorrow.
  13. _Gus
    _Gus Member
    406Coins
    I've now beefed up the connecting rods a huge amount, and beyond just knowing that they're not going to break, I also think that they look awesome. The original rods turned out to be a little less than 5/16ths, and so I had to add some plastic tubing to stop any potential rattling, so now it fits like a glove. The reinforcing pipe is low carbon steel, and has an ID of 3/8ths, and an OD of 3/4ths, so it is quite strong.
    Here's some pics:
  14. _Gus
    _Gus Member
    406Coins
    Another update, this time about the SimTools problem:
    When I swapped the arduinos it turns out I incorrectly did the pin13-a1 connection on the sabertooth, so it was pin13-a2 instead. I fixed this, and it appears to work now. Then, the arduino which was originally in the faulty pair was having issues connecting to SMC3 Utils as well as redownloading the code, which I tried to do to fix the connection issue. I had backordered a new arduino because I thought that might be the issue, so I swapped those out, and now all is good with the arduinos.
    Now my problem is that I have boosted the max pwm on the motors from 100 to 235 via the smc3 util, because the motors were not able to lift me up at 100. Now when I try to lift myself, or when I move the SimTools axis quickly, the Sabertooths freak out. They seem to turn off, along with the motors, and then periodically turn back on one at a time and move the motor a tiny bit, then turn off again. When they do this, the green and the red lights are on on the board. I think this is all happening because I have the whole thing plugged into the wall on the same circuit as my computer, and a minifridge, and so when the motors attempt to draw their full 1200 watts, they can't, or atleast the psus can't supply that much, which is causing the sabertooth error.
    If anyone else has experience this issue let me know, but tomorrow I'm going to try running in an extension cord to the garage to get this all on a different circuit, and see if that works. The important part though is that I'm past the simtools errors!
    Sorry if this reply is riddled with mistakes---It's almost midnight and I had a really long day today.
    153,764Coins
    +11,149 / 57 / -2
    If the motors are struggling to provide the required torque you could also try a smaller CTC on the levers.
  16. anatachaikiet
    anatachaikiet New Member
    184Coins
    thank you
  17. _Gus
    _Gus Member
    406Coins
    Unfortunately, using a different circuit didn't fix the problem. I'm going to try using a different power strip though, because I know the one I'm using has surge protection, and may be causing the issue...
    EDIT: Nope, didn't fix it. I'm thinking that this isn't just a torque issue though, because the math says I should have plenty of torque, and if I don't have enough, the motors should just run slower.
    I also don't think its a torque issue because an identical failure also occurs when I move the motors too quickly (w/o weight), where the motors all turn off, and sort of push up a tiny bit one at a time. When this happens, the error and status LEDs flash on the sabertooth, which according to the dimension engineering site:
    "Sabertooth 2x32: If voltage is too low, Status and Error will flash. If voltage is too high, Status and Error will glow."
    so I'm thinking I have a voltage issue... but I don't quite understand what it could be, as my PSUs output 24v and can handle 480 watts, and my motors are 24v 200 watt motors. Suggestions or advice would be appreciated.
    For right now I'm going to put the PWM back down to 100 to setup the axes without issues.
  18. _Gus
    _Gus Member
    406Coins
    While I've not yet figured out how to get it to move me, I have configured all of the axes, and it is officially alive! Here's the motion test video:
    153,764Coins
    +11,149 / 57 / -2
    Great to see your rig moving :thumbs
    I am repeating myself but I do think your lever CTC is too large for the intended mass and likely your levers are also at an inefficient angle.
    Levers provide maximum torque at 90 degrees to the rods, and over 38 odd degrees either side of that are pretty inefficient with respect to torque.
  20. _Gus
    _Gus Member
    406Coins
    Apologies for ignoring your last reply. I misintepereted the motors specs as having variable max torque given the max rpm of the motors, but in reality the manufacturer was describing the spec for different gearbox options. This means I have much less torque then I thought, and my motors will be putting out about 25.4 Nm of torque (I'm rounding to 25), or enough to lift only 264.5 pounds total, including the upper portion of the frame, given my CTC length. I redid the math with the correct specs, and leaving ample padding, I think my levers should be about 3.3", or about 3 and 5/16". This is a big step down from my current 5" arms, but I guess I'll have to make due. I'll try and. redrill the lever arms to incorporate a 3 5/16 length between the shaft and joint.
    Also, thank you for the advice about the arm angle. I'll try and figure out how to fix this. Right now the arms cannot fully turn down to a 90 deg. angle, without hitting the frame, and before they even get down close, the rod will hit the lever arm.
    Lots of things to think about!
    Just out of curiosity, how long are your guys's lever arms?
