Ayuda mini simulador con servos sg90
Discussion in 'DIY Motion Simulator Projects' started by sbdtoni, Aug 5, 2019.
  1. sbdtoni
    sbdtoni Member
    207Coins
    Hola a todos, estoy intentando hacer un mini simulador 2 dof con servos sg90 y con arduino uno y no consigo hacerlo funcionar ni con el xsim si con el simtools, necesito el scketch de arduino y como hacer que la arduino se conecte con el xsim o simtools, si alguien me puede echar una mano será bienvenida.
    u saludo y gracias a todos.
  2. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    Hi sbdtoni,
    The official language of the forum is English, you can use the google translator for example.
    You should stop by too, you'll see how they welcome you.
    https://www.xsimulator.net/community/threads/are-you-a-new-member-introduce-here.1737/
    That said, I put a link for you to serve yourself.
    https://www.xsimulator.net/community/forums/simtools-compatible-interfaces.25/
    Hola sbdtoni,
    El idioma oficial del foro es el inglés, puedes usar el traductor de google por ejemplo.
    Deberías pasar por aquí también, verás como te dan la bienvenida.
    Dicho esto, te pongo un enlace para que te sirvas tu mismo.
  3. sbdtoni
    sbdtoni Member
    207Coins
    Hi i'm sorry not problem we will write in English, immediately i'll putt a post in presentations , many thanks for your help, kond regards.
  4. sbdtoni
    sbdtoni Member
    207Coins
    Hello everyone, I am trying to make a 2 dof mini simulator with sg90 servos and with arduino one and I can't get it to work even with the xsim if with the simtools, I need the arduino scketch and how to make the arduino connect with the xsim or simtools, if someone can help me out, it will be welcome.
    u greeting and thanks to all.
    151,528Coins
    +11,042 / 56 / -2
    Follow the advice here on how to configure an RC servo powered sim model: https://www.xsimulator.net/community/threads/2dof-simulator-servo-model.6851/#post-77270
  6. sbdtoni
    sbdtoni Member
    207Coins
    hi to all, i tried to make works a mini simulator with servos sg90 and Arduino uno but i can't the servos when i put simmtools have a little moviment but after i tried to testing and move and not works, any suggestion? many thanks for your help.
    kind regards.
    151,528Coins
    +11,042 / 56 / -2
  8. sbdtoni
    sbdtoni Member
    207Coins
    ok this night when return home i'll do.
    many thanks.
    kind regards.
  9. sbdtoni
    sbdtoni Member
    207Coins
    I attach here the pictures of the configuration used for SimTools.
    In the arduino code "RCModelSimToolsMode.ino", provided here: https://www.xsimulator.net/community/marketplace/rc-model-code-for-arduino-uno-2dof-expandable.89 , I only changed the values for the pins to the pins I attached the actuators to, is there anything else I must change in the code?
    To test if it works, in SimTools I enter the "Output Testing" tab, click "Turn On", I select the "(a) Axis Output" and modify the % values for the Axis Output Amount of Axis 1a and 2a, am I doing it right? Should this make the motors work (It doesn't)?
    When I load the arduino code to the arduino UNO, the motors stay in one position, and when I "Turn On" the "Output Testing" in SimTools, they both move to the "initial" position, so this makes me think that they detect SimTools correctly, but I can't seem to make them move modifying the values of the Axis Output Amount of Axis 1a and 2a.
    Thanks beforehand.
  10. NjMotion
    España
    1,490Coins
    2DOF, 6DOF
    I don't know that code but I think that for SimTools 2.0 you should put in interface settings an "a" after 1 and 2. R <Axis1a>
    151,528Coins
    +11,042 / 56 / -2
  12. sbdtoni
    sbdtoni Member
    207Coins
    Hi @NjMotion and Noorbeast many thanks for your help and support :thumbs, finally works with ouput testing have movement i donwload LFS and this nigth i'll test, some sugestion to work with this game?
    another time many thanks for your help and support.
    PD
    i have 6 servos next project a 6 dof...... i'll need your support another time ;)
  13. noorbeast
    151,528Coins
    +11,042 / 56 / -2
    Glad you got it working :thumbs
    The link I provided also covers expanding the code for 6DOF.
  14. sbdtoni
    sbdtoni Member
    207Coins
    hi, the motors works perfect with LFS many thanks for your help to make this project, when i finished i'll upload a video with the final result one more question wath is a good configuration for the axis for a 2 dof (roll, Pitch,sway etc.)
    many thnaks.
  15. sbdtoni
    sbdtoni Member
    207Coins
    Hi guys first of all many thanks for your help with this project I just finished my mini motion 2 dof and this is a result I can’t upload video is too large :confused:
    Kind regards
  16. noorbeast
    151,528Coins
    +11,042 / 56 / -2
  17. sbdtoni
    sbdtoni Member
    207Coins
    hi Noorbeast another time thanks, this is the video from youtube
