Question After the DR 2.0 update and support for VR, the motion simulator plugin seems to be invalid.
Discussion in 'Dirt Series' started by wp8051, Aug 8, 2019.
  1. wp8051
    wp8051 Racing simulator player Gold Contributor
    China
    234Coins
    AC motor, Motion platform, 4DOF
    Today, DIRT RALLY 2.0 has been updated to version 1.7. It can already support VR, but the motion simulator has not responded. I tried to patch the plugin again. It is still useless. I don't know if you have the same situation, or only Can I wait for the next version of the plugin to be released?
    152,307Coins
    +11,069 / 56 / -2
  3. wp8051
    China
    234Coins
    Thank you, I saw it, I replied to the question in the other post.
  4. Raredog
    Raredog Active Member
    Denmark
    25Coins
    2DOF, JRK
    I just purchased the game, motions works fine for me.
    As I am using a seatmower I have not needed motion cancellation, but this seems to need it...
  5. wp8051
    China
    234Coins
    This is impossible.
    After the dirt rally 2.0 was updated to version 1.7, the new hardware_settings_config file was regenerated when the game was launched. This file is not the same as the old version.
  6. wp8051
    China
    234Coins
    Oh, I seem to know how to do it, thank you for inspiring me.
    I removed the patch first, then restarted the game, generated a new 25th version of the hardware_settings_config file, and then re-patched. It may be useful now, but it's too late. Try it again tomorrow.
  7. patoch
    patoch l'AUvergnat de france Gold Contributor
    63000 clermont ferrand
    31Coins
    3DOF, SCN6
    hello jai aussi ce probleme si ta la solution ca serais sympa ce jeu me manque trop!! merci
  8. patoch
    31Coins
    3DOF, SCN6
    oui jai le méme probleme le plugin et bleu tout et ok du coté de game engine
    152,307Coins
    +11,069 / 56 / -2
  10. wp8051
    China
    234Coins
    Hello, I have solved this problem now, everything is as perfect as before.
    First, you need to remove the plugin patch for DR2.
    Then, restart DR2 once and then patch the DR2 plugin again.
    Everything is done.
    I have been connected to Oculus rift cv1 on my computer, and I don't want to automatically launch VR every time I enter the game. In the documentation folder, find the "hardware_settings_config" file in the DR2 directory.
    Edit the contents of this file and change to the following:
    <vr enabled="false" eyeDistanceMultiplier="1.000000" lockedOrientation="false">
    I hope you enjoy yourself!
  11. patoch
    31Coins
    3DOF, SCN6
    thank you i will try !!
  12. sulfail
    sulfail Member
    Mason
    vigo(pontevedra) SPAIN
    205Coins
    Dirt rally 2.0 looks great in lenovo explorer in vr, but the movement with simtools only works the first stage, if you go out to the menu or load another new stage stops working, at first it flashed in game engine, disable shutdow and centering , I stop blinking but I do not soluccido the problem, only works once and I have to restart simtools to make it work again, a shame because dirt rally feels great and I do not get dizzy anything, what I do not understand is because some works them and others do not? the other games work perfectly for me.
    Greetings to all and take care, happy summer.
    aahh I forgot I used the translator excuse me.;););)
  13. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Sorry, it doesen't need motion cancellation, it was a mix of bad settings on my part :)
  14. Martyn
    Martyn Member
    Europe
    29Coins
    2DOF, SCN6
    Exactly same problem here, motion works only until i get to the menu, then game engine needs to be restarted:(
  15. Raredog
    Denmark
    25Coins
    2DOF, JRK
    After the 1.8 update, motion is no longer working.
    The reason seems to be, that a new file has been added:
    documents\mygames\dirtrally2.0\hardwaresettings\hardware_settings_config_vr.xml
    Just copy these lines from YOUR hardware_settings_config file to the _vr file:
    <motion_platform>
    <dbox enabled="false" />
    <udp enabled="true" extradata="3" ip="127.0.0.1" port="4123" delay="1" />
    <custom_udp enabled="false" filename="packet_data.xml" ip="127.0.0.1" port="20777" delay="1" />
    <fanatec enabled="false" pedalVibrationScale="1.0" wheelVibrationScale="1.0" ledTrueForGearsFalseForSpeed="true" />
    </motion_platform>
    And it works again :)
  16. sulfail
    sulfail Member
    Mason
    205Coins
    Nothing continues with the same problem when changing the test or pausing to adjust simtools is lost, even if you register data there is no movement and you have to restart dirt rally to run another test, at least you can run a single test after not leaving the menu . It does not work well
    friends.:(:(:(:(:(:(:(
    Excuse me, I use the translator.:(:(:(:(:(:(
  17. yobuddy
    51,099Coins
    Is everyone that is having the problem using VR?
    (Would explain why I'm not having the issue on my test machine anyway)
    Could someone post the hardware_settings_config_vr.xml file unedited.
    If all we have to do is patch an additional file, this would be an easy fix!
    Take care,
  18. patoch
    31Coins
    3DOF, SCN6
    i do not use the vr jai on 3 screens and the problem and the same it works 1 time after repatcher.( i have a 3 dof prosimu) and after it works more!! and the plugin him and in blue. l am novice!! i can no do much to help
  19. Raredog
    Denmark
    25Coins
    2DOF, JRK
    Oh, sorry - yes i believe it is only a problem if you are using VR. I had no problems before the update, and with the lines added it works flawlessly again :)
  20. JZargo
    JZargo New Member
    business owner
    morciano di romagna
    83Coins
    3DOF, Arduino
    Same here guys, and I also use Vr.. Game Engine start blinking and i look this
