Help making an inexpensive motion simulator.
Discussion in 'DIY Motion Simulator Projects' started by lindo123, Aug 14, 2019.
  1. lindo123
    lindo123 Gamingfeeling
    none
    United Kingdom
    394Coins
    2DOF, 3DOF
    Hello, if you're reading this you're probably wondering what i need help with. I'm planning on making a 3Dof platform. As I wan't it to be inexpensive, I didn't want to blow the budget on fancy motors so I opted for less powerful ones. This does mean I have to have some kind of support whether it's in the middle or on the outside. I have noticed that many people use springs like this: [​IMG]
    However, springs are either to weak or really expensive do you know what i could use?
    154,028Coins
    +11,165 / 57 / -2
    I took a somewhat unique approach with my compact 3DOF and repurposed the tilt mechanism off my high end DX office chair: https://www.xsimulator.net/community/threads/dx-compact-simulator.5866/page-13#post-81922
    The upside of this is that it is designed and calibrated for a user + chair by default and is also adjustable. The downside is that it travels through a small arc, though I use that to advantage in things like surge settings, and it has a useful but limited range for heave.
  3. PaulB
    PaulB Titanium2dof
    Canada
    723Coins
