help confused guy
Discussion in 'New users start here - FAQ' started by TomBerkovits, Sep 6, 2009.
  1. TomBerkovits
    TomBerkovits New Member
    0Coins
    hi all,
    I'm working on a small project of building homemade wheel pedals and gearbox.
    I decided to add Force-Feedback system the the wheel, so i started to search for a program which can send the FF signal from the game to exterior motor. As you can see I found the X-sim.
    The problem is that the program is too complicated and i cant find the FF signal there and how to send it out to any exterior device.
    Hope to have some help here and sorry for the poor english :blush:
    Tom
  2. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    If you want proper FF (I am not sure that x-sim is right for this things ) only cheap and easy way is to buy FF wheel and use its electronic.
  3. TomBerkovits
    0Coins
    I dont want to use any FFwheel, i want to do everything by myself.
    i saw in the X-sim the lateral force which looks similar to the FF of the wheels. How can I send it to exterior device?
  4. Mambo
    Mambo New Member
    Czech Republic
    288Coins
  5. bvillersjr
    bvillersjr Active Member
    Ohio, USA
    438Coins
    Why not? Are you aware of a data elelement that the FF Wheels use as input that it not available from our plugins or Yoda?
  6. Mambo
    Mambo New Member
    Czech Republic
    288Coins
    I dont examine it mutch, but i thougt that it work well only with simbin type of FF (where you get FF simulate by predefine effects), but as i say i dont examine it mutch. I must try it for example with LFS what that send out. But it make sence that it should be fairly same.
  7. TomBerkovits
    0Coins
    thank you all
