Question Axis plugin. Offset % How to calculate?
Discussion in 'SimTools Pro & Entertainment Version' started by Trigen, Sep 8, 2019.
  1. Trigen
    Trigen Active Member
    2,891Coins
    Hello
    Im trying to make this work so i can set an offset for where a force starts or stops working.
    What im experiencing is that i need to keep a force to 100% to use 0-1 and the decimals within. If i set 30% on the heave and 40% for the offset it wont work even though it should give a value of 0.4.
    Im quite sure i need to convert lets say 30% for the heave here and turn that number into a 100% range for the TL offset.
    It will also need a flip value for code that needs 40% to be -0.4 or whichever number that will be after the conversion as an example
    Id appreciate any help for the code
    Code:
                    'DOF3
                    Select Case ._Axis1DOF3
                        Case "-"
                            Axis1_Value3_Out = 0
                            Axis1_TL_Offset = 0
                        Case "Heave"
                            'Get percent used for DOF
                            Axis1_Value3_Out = _Heave_Input * (._Axis1PER3 * 0.01)
                            Axis1_TL_Offset = ._Snap_TL_Upper_per * 0.01
                            'OffsetDiv = (Axis1_Value3_Out / Axis1_TL_Offset) * 100
                            'finalnr = OffsetDiv * 0.01
                            'Flip if necessary
                            If ._Axis1DIR3 = True Then
                                Axis1_Value3_Out = Axis1_Value3_Out * -1
                            End If
                            If Axis1_Value3_Out > 0.8 Then
                                Axis1_Value3_Out = Axis1_Value3_Out * 0
  2. yobuddy
    51,557Coins
    This sounds like a dead zone and boundary filter?
  3. Trigen
    2,891Coins
    Depends on the definition of a DZ, in the normal sense then no. A DZ is just a narrow band in the middle to remove minor forces in the center (depending on where the flap is) which is why it has been limited to 10% in the software. For the boundary, yes. It will stop it at X%
    Its an offset to where the force should start at.
    What the main thin and usage is that it is taking the traction loss (using heave for testing here) and slamming it to 0 (or continue as normal) once it passes a threshold of say 80% This way it will not lower the flap in the G seat until it reaches it.
    The calculations would be the same for both just in the opposite way though as far as i know. It just needs converting the first 80 of DOF to be 100% range for the offset.
  4. yobuddy
    51,557Coins
    This is how the DeadZone works thou?
  5. Trigen
    2,891Coins
    Its an offset, not a DZ ;)
    DZ in Simtools is a max 10% that works from any given point to reduce spiking etc. Just think of it as a boundary in reverse.
    In any case if you dont mind just ignore all this and help me out with the conversion. I got it working as i wish i just need the conversion.
  6. yobuddy
    51,557Coins
    I don't understand what your doing different than the dead zone filter does is all.
    So I thought I would jump in the conversation to see if i could help.
  7. Trigen
    2,891Coins
    Got ya and i appreciate it but sometimes i just want a straight answer to what question i'm actually asking. Im pretty sure you know the answer to this one ;)
    Ill explain this in detail
    DZ 0-10% from any given point the axis is at, agree? Could be wrong but I can't do anything with 10 and I've asked about this In relation to traction loss before.
    Boundary 0-100% works from to X% point
    Offset 0-100% Force does not work until X% if you set it to 50% it will not do anything for the first half of the axis.
    In my case a G seat. Sway raises the axis, Traction loss lowers it. Simplified i set both to 50% and they will cancel each other out. Now i dont want Traction loss to have any effect for the first 80% (80% of 50)so it does not interfere with sway. If i then offset Traction loss offset to 80% or 0.8 (it needs -0.8) in the code then it will accomplish this.
    Code:
                    'DOF4 Traction loss
                    Select Case "Extra1"
                        Case "-"
                            Axis1_Value4_Out = 0
                            Axis1_TL_Offset = 0
                        Case "Extra1"
                            Axis1_Value4_Out = _Extra1_Input * (._Axis1PER4 * 0.01)
                            'Flip if necessary
                            If ._Axis6DIR3 = True Then
                                Axis1_Value4_Out = Axis1_Value4_Out * -1
                            End If
                            ' get offset for Traction loss
                            Axis1_TL_Offset = _Extra1_Input * (._Snap_TL_Upper_per * 0.01) ' not usin this at the moment
                            ' Tune for kick at snapout or overall feel
                            If ._Snap_TL = True And Axis1_Value4_Out > -0.8 Then
                                Axis1_Value4_Out = Axis1_Value4_Out * 0
                            End If
                            If ._Snap_TL = False And Axis1_Value4_Out > 0 Then
                            End If
  8. Trigen
    2,891Coins
    And just for arguments sake I don't have access to any filter code, just the example 3 dof code. also for dz and maybe we are talking past each other I have to think within the bounds of how it's set in the current Simtools but technically dz if as on a joystick then it would be fine
  9. yobuddy
    51,557Coins
    If you want help with code, you need to give people a chance to understand what you trying to do and or need.
    Which is why I was trying to figure out what you needed. :thumbs
    Yes, its the same.
    You would just need to modify the percentage it allows is all.
    Code:
    #Region "DeadZone"
        '~~~~~~~~~~~~ Deadzone ~~~~~~~~~~~~
        Private DeadZone_Axis As Double = 0
        Public Function DeadZone(InputValue As Double, DeadZoneValue As Integer) As Double
            If DeadZoneValue = 0 Then
                'Return InputValue
                Return InputValue
            Else
                If InputValue < DeadZone_Axis - (DeadZoneValue * 0.00001) Then
                    'compute outputs
                    DeadZone_Axis = DeadZone_Axis + (InputValue - (DeadZone_Axis - (DeadZoneValue * 0.00001)))
                    'keep in range
                    If DeadZone_Axis < -1 Then
                        DeadZone_Axis = -1
                    End If
                ElseIf InputValue > DeadZone_Axis + (DeadZoneValue * 0.00001) Then
                    'compute outputs
                    DeadZone_Axis = DeadZone_Axis + (InputValue - (DeadZone_Axis + (DeadZoneValue * 0.00001)))
                    'keep in range
                    If DeadZone_Axis > 1 Then
                        DeadZone_Axis = 1
                    End If
                End If
            End If
            'Return rescalled InputValue
            Return DeadZone_Axis + (DeadZone_Axis * (DeadZoneValue * 0.00002))
        End Function
    #End Region
    Take care,
  10. Trigen
    2,891Coins
    Thank you, appreciate that!
    And yeah, what seems very clear to me may not be for others, lesson learned :)
    Now since i dont know how to use this as a function (can use the code anyway of course) ill have to figure that out. Its good for learning VB
  11. Trigen
    2,891Coins
    Ive been testing this a lot (in 2d advanced) and DZ works the way I've described it from the beginning, not the way a joystick does. Its essentially moving the center point . It will give you a DZ of 10% from the point the axis is currently at not only -0.1 to 0.1. It will start at 0 and give you 10%. If it moves instantly to 0.5 it will give you a 10% deadzone again from there. around. Im assuming you ctrl-c-p the code so its the same.
    If the deadzone worked as a normal deadzone you could call it that but It needs the offset or from Simtools rules a reverse boundary
    This is also why (i think) when i move the heave output test slider to the right it works as normal with no DZ but if i move it to the left regardless of what % its at it will kick in and move to 0 from my IF code. I cant actually make it work like it does in the Generic 2d Advanced filters though so i guess something aint quite right. Either way im rather sure it wont work.
    Code:
        Private Axis1_TL_DZ As Integer = 0 ' Traction loss offset
        Private Axis1_TL_final As Double = 0
    Code:
                        Case "-"
                            Axis1_TL_DZ = 0
                            Axis1_TL_final = 0
                        Case "Heave"
                            Axis1_TL_DZ = ._Snap_TL_Upper_per
                            Axis1_TL_final = DeadZone(Axis1_Value3_Out, Axis1_TL_DZ)
                            'Flip if necessary
                                Axis1_TL_final = Axis1_TL_final * -1
                            End If
                            If Axis1_Value3_Out < Axis1_TL_final Then
                            End If
