F1 2Dof simulator
Discussion in 'DIY Motion Simulator Projects' started by estami, Sep 21, 2019.
  1. estami
    estami New Member
    Industrial maintenance
    Alcañiz Spain
    95Coins
    Hi, I would like to show you my project that I have been working on for a while.
    Now it takes a while to stop but I'm taking it back.
    My idea was that the driving position approximates that used in an F1.
    Something similar to this style
    I started my work doing a basic foundation, and a base where I would place it later.
    Little by little I placed the anchors and bars for movement.
    Modifying the kneecaps to make a level adjustment
    Reinforcing the connecting rod part with bearings so that the engine does not suffer
    Whole assembly assembled........
  2. estami
    estami New Member
    Alcañiz Spain
    95Coins
    We continue .....
    Motors and electronics ... part I have not used
    Fastening the steering wheel and pedals IMG_2445.JPG IMG_2446.JPG IMG_2447.JPG IMG_2448.JPG IMG_2449.JPG
    and my homemade backet jjjjj,
  3. sbdtoni
    sbdtoni Member
    207Coins
    Hi nice project i’m Working in a similar project I have some questions about the sketch of arduino, what sketch do you use? Works fine? Can send me if works fine? Many thanks.
    Best regards
    152,553Coins
    +11,087 / 56 / -2
  5. estami
    estami New Member
    Alcañiz Spain
    95Coins
    Good afternoon we continue showing a little more of the project.
    Engine mounts, in the last image you can see the pinion that will move the hall sensor.
  6. estami
    estami New Member
    Alcañiz Spain
    95Coins
    The coupling of the engine finally did not work well in subsequent publications I will show the modifications I made since it ended up loosening
  7. estami
    estami New Member
    Alcañiz Spain
    95Coins
    Modify the motors to isolate the ground .....
