Question Limiting Spikes in iRacing profile
Discussion in 'SimTools DIY Version' started by Michael Jeffries, Sep 11, 2019.
  1. Michael Jeffries
    Michael Jeffries Member Gold Contributor
    485Coins
    Motion platform, 4DOF
    Does anyone know how I can limit spikes when some of the more "eager" drivers slam their cars into mine.
    I dont want the rig jumping off the floor when there's a hard impact.
    How can I adjust to fix that issue in simtools?
  2. Sebj
    Sebj Active Member
    Canada
    492Coins
    Well not a simple task. You could use the boundary filter to tune down the maximum effective movement of each axis thereby limiting the peaks. Try that with sway and surge.
  3. Michael Jeffries
    485Coins
    If I limit the boundary wouldnt that shorten the amount it moves and there by make the spike worse? Or is that only if it's axis limited?
  4. Sebj
    Sebj Active Member
    Canada
    492Coins
    I use boundary with heave for example. It cuts off the max travel during larger moves only while maintaining the nuance of smaller inputs. If you limit the axis then you still get the maximums but at shorter movements.
  5. Sebj
    Sebj Active Member
    Canada
    492Coins
    For example, in iRacing for heave Extra 2
    I used to run a max axis at 5% to limit the travel because I was finding that being on the grass any more axis produced huge spikes and it felt violent. But I was losing fidelity with smaller movements.
    I ended up going with 100% axis and adding a boundary of 10 instead. Much better, lots of subtle details but none of the major spikes at the high end.
  6. Michael Jeffries
    485Coins
    I get it now. Thanks ill play with it.
  7. baxbax
    baxbax New Member
    135Coins
    could you put an image , about, this configuration? I don't understand, where you inserted this settings?
    Thanks in advance
    Marco
  8. Sebj
    Sebj Active Member
    Canada
    492Coins
    Yes for sure a bit later when I get a chance.
    What does your motion rig look like?
    Did you see mine?
  9. Sebj
    Sebj Active Member
    Canada
    492Coins
  10. baxbax
    baxbax New Member
    135Coins
    Thank you very much , for these informations.
    This evening I will try.
    You did a fantastic job, with your sim! Very professional!
    Mine is a 2DOF very artigianal.
    Is it a your project?
    Bye
    Marco
  11. Sebj
    Sebj Active Member
    Canada
    492Coins
    Thank you, yes it is my project.
