problem 2DOF
Discussion in 'DIY Motion Simulator Projects' started by sbdtoni, Oct 3, 2019.
  1. sbdtoni
    sbdtoni Member
    207Coins
    Hello everyone, I have a problem and I have not just solved it, I have mounted the 2dof system in MODE2 with IBT2(changed the sketch in Arduino) and when I test with SMC3 with the potentiometers I can move the motors when I get to the orange line, but when I put it in motion mode they don't move, does anyone have any idea what it can be and that I have to change.
    thank you.
  2. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    Hello, have you followed the corresponding steps to adjust the potentiometers and that the direction of rotation is correct? It would be helpful to attach photos of your configuration to be able to move forward with the problem
  3. sbdtoni
    sbdtoni Member
    207Coins
    I have done the test described in the SMC3 tutorial by setting Kp, Ki, KdPWMmin, PWMmax, PWMrev to 0 and clip and limit a255 I have connected the motors I have set Kp to 400 and I have slowly climbed PWMmax, but the motors do nothing, they just move If I move the potentiometers, I have 500K potentiometers on, can you think I am doing wrong? thank you
    151,504Coins
    +11,041 / 56 / -2
    The pots should be connected to the motor for SMC3 setup, is that the case?
  5. sbdtoni
    sbdtoni Member
    207Coins
    Ni i Made this circuit changing in the Arduino sketch mode1 to mode2 pots are installed like picture
    151,504Coins
    +11,041 / 56 / -2
  7. zapata_h
    España
    308Coins
    If at any time the engine exceeds the CLIP line, arduino will order to block the engines and must restart the board again, maybe this is the case?
  8. sbdtoni
    sbdtoni Member
    207Coins
    Noorbeast, sorry , no the pots not are phisically put with the motors, thanks.
    151,504Coins
    +11,041 / 56 / -2
    Then please connect them.
  10. sbdtoni
    sbdtoni Member
    207Coins
    I have managed to make the motors move, but if I connect the potentiometers it breaks them since they rotate the motors strongly, attached video of how the motors rotate, if someone knows how to mount them so that it does not reduce this I would appreciate it very much, in Simtools I do not get that works, thank you very much
  11. zapata_h
    España
    308Coins
    We go in parts, we assume that you have 10K potentiometers, the potentiometers break them because the motor rotates in the opposite direction and does not find its position, you have to set KP to 0, once in 0 the value of kp slowly increases and the blue line should look for the green line, if not, reverse the polarity of the motor or potentiometer (never both) and try again
    Follow these steps to adjust the potentiometers
  12. MarkusB
    4,214Coins
    Too bad that your pots broke. But now that you need replacement pots anyway, you may want to buy those without an end-stop. Here is an FAQ link that may help you.
    https://www.xsimulator.net/community/faq/how-to-choose-potentiometer.238/
  13. sbdtoni
    sbdtoni Member
    207Coins
    Hi friends finally the motors works fine with smc3 but I can’t works with simtools, I read the official tutorial and I can’t if someone can explain how make to works I’ll be happy.
    Many thanks.
    Best regards
    151,504Coins
    +11,041 / 56 / -2
    Please post pictures of all of your SimTools settings.
  15. sbdtoni
    sbdtoni Member
    207Coins
    Hi thanks for your help enclose photos of my configurations
  16. noorbeast
    151,504Coins
    +11,041 / 56 / -2
    Try 500000 BitsPerSec in your Interface Settings.
  17. sbdtoni
    sbdtoni Member
    207Coins
    Hi Noorbeast perfect works many thanks, but not works with LFS I open like administrator and not work I patch the game in the folder of C:/ LFS is in another folder that I need to install the patch?
    Many thanks
  18. noorbeast
    151,504Coins
    +11,041 / 56 / -2
    Did you run a LFS race in first person mode before patching, as that generates some required files?
    If not then un-patch LFS, close SimTools, run a race, then re-patch LFS.
  19. sbdtoni
    sbdtoni Member
    207Coins
    Hi many thanks, I made like you says....and works perfectly, many, many thanks, next step the mechanical...... kind regards
