Showroom New DIY 3DOF dynamic workstation project UPGRADE 4DOF
Discussion in 'DIY Motion Simulator Projects' started by Milani Fabio, Feb 27, 2019.
  1. MENANDRO DALIDA JR
    MENANDRO DALIDA JR Member
    51Coins
    Hi Fabio, Thanks for your quick response. I'm so relieved, I thought that my motors cant meet the specifications for my sim. Looking forward to starting my project and as soon as the motors arrive. By the way, Sabertooth 2x32A is way too much expensive than motors. Can you recommend a cheaper one?
  2. Milani Fabio
    Milani Fabio Active Member
    Italia
    718Coins
    I chose the Sabertooth + arduino configuration because I saw other projects that worked well and also because I could better understand their settings.
    Not having any knowledge I relied on the scheme in my posts and therefore I was also obliged to use these components.
    From what I understand the choice Sabertooth is almost obligatory because it is the only one that supports the amps of powerful engines.
    I can't recommend anything else.
    Hello
    151,486Coins
    +11,041 / 56 / -2
    Quality hardware costs, like Sabertooth, tends too work out in the long run in terms of reliability and longevity.
    But if you want a cheaper option try 43A IBT-2 in Mode 2 using SMC3 code: https://www.xsimulator.net/communit...3dof-motor-driver-and-windows-utilities.4957/
    Be aware that cheap MM clones often have issues: https://www.xsimulator.net/community/faq/reputable-monster-moto-suppliers-testing-before-use.158/
  4. hannibal
    hannibal Active Member
    4,491Coins
    its worth the money. everyone uses sabertooth. at the end u waste more time and money going cheap..
  5. MENANDRO DALIDA JR
    51Coins
    Thanks Sir @noorbeast , Lots to learned with your advised. Ill go for the sabertooth.
  6. MENANDRO DALIDA JR
    51Coins
    Yes Indeed. Ill go with the sabertooth. Thanks for the advised sir @hannibal
  7. MENANDRO DALIDA JR
    51Coins
    Thanks, Sir @Milani Fabio, Ill go with the sabertooth. By the way, I've seen your video with the button right on your chair. Is that for the Emergency stop? if that so, where to attach/wire that.
  8. MENANDRO DALIDA JR
    51Coins
    Hi Fabio, where did you get the 3D gears for potentioner?
  9. MENANDRO DALIDA JR
    51Coins
    Hi Favio, is it ok if i use more than 6.8 ohm? Like 8 ohm?
  10. MENANDRO DALIDA JR
    51Coins
    Hi Fabio, do you have actual size measurements of your gears nor drawing details with the size?
  11. MENANDRO DALIDA JR
    51Coins
    Hi Fabio, can you share one by one the graphics sketch. Pls? Thanks
  12. Milani Fabio
    Italia
    718Coins
    Hello guys,
    I came back to present you my new project, or rather, update my sim 3 DOF.
    I would like to add a movement, the loss of traction.
    But I wanted it independent of other movements, a DOF engine dedicated only to traction loss.
    Here is my solution starting from my original project and keeping most of the old pieces.
    I added the lower base.
    A new star-shaped box on the moving base (the green one) to house the front for the fulcrum.
    The upper wheels and above all two trolleys under the plates, which serve to anchor the upper part to the lower base when the lateral movements are fast (chicane).
    The fourth engine in a position inside the structure, I wanted to keep the old measures for the little space in the room ..... only 6 cm more in width.
    At the moment it is only on sketchup., I hope soon it becomes a reality.
    I am attaching the video of the project in sketchup (in recent months I have learned to use the softwere a little bit .... beautiful !!!!)
    See you soon
  13. MENANDRO DALIDA JR
    51Coins
    Hi Fabio,
    Can you share with me your Arduino code? Please. Thanks in advance :)
  14. Milani Fabio
    Italia
    718Coins
    Hi
    I use the Wanegain code.
    the Wanegain arduino code was sent to me directly by Wanegain.
    You ask him with a PM, he is a kind person, he will have no problem sending it to you.
    If you have to make sims like mine I suggest you join this forum, there are so many projects and tutorials like mine.
    https://pcshm-simulateurs-homemade.clicforum.com/index.php
    Hello
  15. MENANDRO DALIDA JR
    51Coins
    Yes, Fabio, your project is what I making too. Thank you for your quick respond really appreciated :)
  16. anatachaikiet
    anatachaikiet New Member
    178Coins
    hello sir you can give me drawing dimension gear to gear for hall effect sencer for me printer 3d
  17. Milani Fabio
    Italia
    718Coins
    Hi Anatachaikiet,
    I didn't make the gears out of them, they designed them a 3D print shop, I gave them all the specifications and they designed it.
    I only have the files in stl format, but I can't load it in the post because it tells me that the stl format is not an allowed extension.
    I'm sorry.
    • Disagree Disagree x 1
  18. Milani Fabio
    Italia
    718Coins
    This is the project I gave to the 3D printing shop.
  19. anatachaikiet
    178Coins
  20. Milani Fabio
    Italia
    718Coins
    Hello guys,
    after a short pause I resumed the project of the previous post for the upgrade from 3DOF to 4DOF.
    I made some small changes, the most important was to move the engine to the opposite side.
    Here is the project from pc to reality.
    Central star 3DOF
    Upgrade Central star 4 DOF
    Fixed base
