Question Need Help Violent shakings. Simtools / Sabertooth
Discussion in 'SimTools DIY Version' started by Patte83, Nov 5, 2019.
  1. Patte83
    Patte83 Member
    24Coins
    Hello every one :) I really need help to solve a big problem i got in Sim tools / SAbertooth.
    When i test the chair in SMC3 it works fine and smooth but when i play a game it works fine for 5 min then one of the motor shakes violently. Only way to stop it is to turn off Sim tools and then put SMC3 on to make it stop. I'm lost i got no ideas left. Please have a look at pictures all advice is important !!
    ( Motor ) ( Transtecno model EC180240 )
    Volts 24
    Watt 250
    amps 15
    _____________
    x 3 ( LRS-350-24 Power supply )
    Output 24v- 14.6A
    Input 100-120 6.8A / 200-240 3.4A
    Arduino Uno / Orginal
    2x32 Sabertooth
    153,758Coins
    Can you please advise what game you are using with SimTools and post pictures of all of your settings
    I also want to confirm that your are not running SimTools and SMC3 at the same time.
  3. Patte83
    Patte83 Member
    24Coins
    Hello :) Its all the games i try Assetto corsa competizione / Xplane 11
    I do not use SMC3 while using Sim tools.
    Picures uploaded
    NOTE !! FIXED /// DONT USE HEAVE EFFECT ON 2 DOF :)
  4. BlazinH
    16,689Coins
    That's not fixed. And your axis assignment allocation's are wrong and each line should total 100 when you add all dofs together.
    153,758Coins
  6. Patte83
    Patte83 Member
    24Coins
    Ok thanks..
  7. Patte83
    Patte83 Member
    24Coins
    Nah no luck same issue. Buuhuu. Is there a guide how to change the Baud rate? I did not really understand the Pin 8 thing.
  8. BlazinH
    16,689Coins
    Start by fixing this:
    This explains pin 8 grounding:
    And lastly change the voltage clamp settings in Describe from Automatic to a couple of volts above what your power supply is outputting and use resistors.
    This may not solve your issues but the first place to start is to thoroughly read the tutorials and follow them.
    Btw, if you try the pin 8 thing then you must undo it and reset before you can communicate with SMC3 utilities again.
  9. Patte83
    Patte83 Member
    24Coins
    Pin 8 solved it :) thanks a lot for your help :) It really moves great..
