Showroom 2 Dof (for now) Diy actuator motion rig
Discussion in 'DIY Motion Simulator Projects' started by Joey, Nov 6, 2019.
  1. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Motion platform, 6DOF
    Hi all. I'm a electronics and racing enthusiast and i had a go at "trying" to build a pretty much 100% Diy motion rig.
    Sorry for my poor English and photo taking skills..
    My original idea was to build stepper motor driven actuators but.. That was a bit harder than i expected haha. Mainly because i was trying to make the steppers hold a position with a simple analog pot.. Bad idea i know now haha..
    So back to the drawing board and i came up with a kind of overkill but sturdy design for the actuators.
    Mind you i don't have welding equipment nor any real metal working tools so i did everything with a 3d printer and a few simple tools. IMG-20190730-WA0000.jpeg
    Thinking a simple acme rod would be enough to push roughly 50kg hahah... Nope can't do..
    So i ordered these
    Then it was time for the electronics...
    I started out actually trying to design and build my own H bridges and although they worked fine it was way overcomplicated and overbuild..
    So after almost frying my psu i went with a more compact and simpler solution haha.
    Also tried to find a cheap and fast dc motor and i had a battery powered angle grinder laying around and it had a pretty beefy 18v very fast dc motor in it. So I bought another one and thats how i sourced my motors ^^
    This is where i am atm. The frame...
    Tomorrow i will post my progress from today.
    Hope you guys enjoy my rookie mistakes and poor craftsmanship ^^
  2. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Upgraded the rope positioning sensor design with belts :cool:
  3. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    More belt upgrades
  4. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
  5. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Has been very busy last few days :thumbs
  6. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Video with motion testing is coming!
  7. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Did some full weight testing just now and damn what power is in those tiny motors!
    At first i was afraid that they lack torque as they're made for speed but boy was i wrong!
    Also i figured the weight of me and the rig itself was enough to keep the actuators from lifting out of the sockets/feet but they definitely need some reinforcement asap!
    Now i need to figure out a way to permanently link them to floor so they don't lift up anymore...
    Also the belts are quite noisy.. Any ideas how to silence them?
    Ps: Funfact. The belts are from a old broken (mainboard) T300 :rolleyes:
  8. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Feet upgrades :cool: As i'm not trusting those tiewraps :D
  9. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Ready for the first few tests :thumbs
  10. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Had some issues with the position pots slipping out of sync.
    So i made a little notch in the axle and printed a better version.
    Should stay in place now :thumbs
  11. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    hug:It works!!!
    153,740Coins
  13. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    The "jerk" is there. But indeed after the 4th gear almost unnoticeable.
    Today i'm going to play around with the pid settings :thumbs
    Also i'm running a 30amp psu atm and ordered a 50amp for some extra oomph :cool:
    Motors although tiny run perfectly cool with some help from a couple of 100mm fans.
    But so far i love it! And i will never ever go back to a static rig :grin
  14. SoftKitty
    SoftKitty Member
    Engine engineer
    Nantong, Jiangsu, China
    - 140Coins
    AC motor, 6DOF
    Are these type 570 motors, looks similar to the ones on my daughter's toy kart.
    can't believe they work so well on a rig.
    I think one of these is around 150w maybe?
  15. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    type 895. 18v 15amp so 270w the diameter is 5.8cm so quite a bit bigger than standard batterypowered powerdrill motors ;)
    As i said they look small but have plenty torque and speed.
    I could probably get away with a even larger gear to pulley ratio because of the speed.
  16. SoftKitty
    SoftKitty Member
    Engine engineer
    - 140Coins
    AC motor, 6DOF
    got it, thanks.
    I searched its price(less than 10usd),
    it's quite a cheap power source,
    I will try this when I build an actuator.
  17. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Yup i took one from a old battery powered angle grinder and ordered another one of banggood for 13 euro.
    But remember to keep them cool as they lose power pretty quickly when they get hot. Also the carbon brushes are wearing pretty fast with this amount of amps so its not a perfect solution..
  18. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
  19. PeterW
    PeterW alias Wickie
    Dipl. Ing. Mb (FH)
    1,766Coins
    Hi Joey
    great work!! congratulation!
    Just a short question because I like the visual impression of your race game. Which game is it and what settings? (snow, daytime,...?)
    Wickie
  20. Joey
    Joey Member
    Technician
    Nijmegen
    436Coins
    Assetto with loads of mods .
    I believe its set to winter textures without snow and the time of day is 9:00am
    Early morning and evening drives are the best. ;)
