Question 2 dof in smc3 not problem,but in simtools left lower right up
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by morningJ, Nov 20, 2019.
  1. morningJ
    morningJ New Member
    - 59Coins
    Hello, my friends! I need help !
    Q:I test in smc3 that both sides of the motor can keep level. However, when entering simtools for output testing, dof 1 will automatically drop to the bottom, while dof 2 will automatically rise to the top, unable to maintain the level. May I ask why?
    153,992Coins
    +11,162 / 57 / -2
  3. morningJ
    morningJ New Member
    - 59Coins
    153,992Coins
    +11,162 / 57 / -2
    I just want to check and have you confirm that testing in SMC3 works as expected, as that is required before configuring SimTools.
    It looks like you are using the old 1.3 version of SimTools, which is depreciated and it does not support current plugins. Update to SimTools 2.4: https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
    Here is the SimTools manual: https://simtools.us/wp-content/uploads/2019/06/SimToolsUserManual-v2.4.pdf
    The difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a>
