Diy 2DOF Simulator Project economic
Discussion in 'DIY Motion Simulator Projects' started by vicborder, Nov 27, 2019.
  1. vicborder
    vicborder Vicborder
    - 529Coins
    Hi, I wanted to show you my future project.
    Material photos
  2. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    Hi @vicborder, welcome to the site.
    In your post you said you wanted to show the community your future sim but you have given us a parts list instead. If its an opinion of the parts you are thinking of using that you are after then the community I'm sure will give you that as I will but it would be an opinion based on not knowing what your intended future sim/project is or would look like. Maybe post some sketches or pics of the idea you have in mind.
    just trying to help
  3. vicborder
    vicborder Vicborder
    - 529Coins
    If Clear, it is my intention only to start by uploading explanations as a project building measure
  4. yellofella
    yellofella Member
    builder
    744Coins
    3DOF, SimforceGT
    Cool. So what design of sim are you thinking of building??
  5. vicborder
    vicborder Vicborder
    - 529Coins
    My design is to move the entire cockpit, 2 engines to a later end i a pivoting point on the gravity axis of the same cockpit, I lack material to build I'll build it slowly
  6. vicborder
    vicborder Vicborder
    - 529Coins
    First electrical assembly, test correct functioning awaiting more material
  7. vicborder
    vicborder Vicborder
    - 529Coins
    First construction in pieces 3d for tests
  8. vicborder
    vicborder Vicborder
    - 529Coins
    I wanted to upload the video, but it only lets me upload pictures
  9. vicborder
    vicborder Vicborder
    - 529Coins
    I just need the material to get to it, change the printed pieces by metal and build the base structure
    154,693Coins
    +11,210 / 57 / -2
  11. vicborder
    vicborder Vicborder
    - 529Coins
  12. vicborder
    vicborder Vicborder
    - 529Coins
  13. vicborder
    vicborder Vicborder
    - 529Coins
    Built Base structure, built built built I paint I'll ride electric part, it S taking shape
