Dirt Rally 2 Plugin v2.3
SimTools plugin for Codemasters Dirt Rally2
  1. Marcocer
    Marcocer Member Gold Contributor
    France Allier Sussat
    - 262Coins
    it's good for me ...with plug'in 2.0
    and lot of problems with 2.3
    see my posts
    thank you Noorbeast
  2. Marcocer
    - 262Coins
  3. Marcocer
    - 262Coins
    my problems with 2.3 plug'in
    same as ,i think , BlueG6o
    game engine crash
    153,703Coins
    It would be helpful if you can expand the error message by using the Details button and copy and past the whole error message here.
  5. Marcocer
    - 262Coins
    35/5000
    I think noorbeast'bear had to hibernate !
  6. HardyG
    HardyG New Member
    North-Rine-Westfalia
    104Coins
    1st: Plugin works fine
    2nd: Plugin only works with motion in VR.. :sos
    no idea what cause this
  7. Outatime
    Outatime New Member
    205Coins
    You have to patch it for the normal monitor version again.
    I had the same problem while trying both versions.
  8. Marcocer
    - 262Coins
    good year to you and never problems with plugins !
    i test PCars2 with 3dof+1 and Oculus Cv1 (with canceling motion ) and Fabulous !
    why with DR2 ,lots of problems ! game or plug'in
    great world
    great life
  9. Marcocer
    - 262Coins
    and Simtools ,in 30mns ,ajust
    but i prefer play DR2 !
  10. HardyG
    HardyG New Member
    104Coins
    could be so easy some times:
    checked the hardware_settings_config.xml / compare to hardware_settings_config_vr.xml
    found this line different from the vr-Setting
    <custom_udp enabled="true" filename="SimToolsCustomUDP.xml" ip="yourOwnIP" port="4123" delay="1" />
    safed it.. and...fun is back :thumbs
  11. Jean Paul Andrade
    Jean Paul Andrade Member
    272Coins
    hello guys, I have some issues with the Dirt rally 2.0 plugin, the first thing is that after complete a race i patched the game, after that I could not get any movement from my sim or any data in the game Engine, I look for the "hardware_settings_config.xml" file and had to make some modifications as shown in the picture attached, after that, the sim start to get data from the game and it started to move, BUT, only works "Pitch" the game engine shows all data (pitch, roll, yaw, extra1, etc) but the sim won't work as good as the other games, this only happens with DIRT RALLY 2.0
    153,703Coins
    What system do you have and what patch path did you use: https://www.xsimulator.net/communit...-32-bit-install-path-for-motion-patching.260/
  13. Jean Paul Andrade
    272Coins
    153,703Coins
  15. Jean Paul Andrade
    272Coins
    I did capture the min/max values, but still no response in roll or TL @noorbeast about the lines I edited in the xml file, is that ok? that was the only way I could make it work, but it was supposed to be made by the patching process right?
  16. noorbeast
    153,703Coins
    You should not need to edit files.
    Why do you have intensity reduced?
    You have 2 lots of Tuning Center values, so I am not sure what values you are using, but at least there is data.
    Temporarily disable firewall and anti-virus, just to check if some other program is interfering.
  17. Jean Paul Andrade
    272Coins
    that's what I thought, still I had to edit to get movement, the intensity level is temporary I was running the tests in a particular track that has a bumpy terrain and the seat was shaking too hard. I will disable the firewall to see if there is any change, I dont have anti virus. just to be clear, all other games I have works perfect so far (project cars 2, assetto corsa, Live for Speed)
  18. Jean Paul Andrade
    272Coins
    hello @noorbeast I did disable the firewall and nothing, so I removed the patch and ran a race again, after that repatched the game and the same thing happen
    this line was added to the XML file: <custom_udp enabled="true" filename="SimToolsCustomUDP.xml" ip="192.168.1.100" port="4123" delay="1" /> but my Sim doesn't move until I change these other lines from this:
    <dbox enabled="true" />
    <udp enabled="false" extradata="0" ip="127.0.0.1" port="20777" delay="1" />
    to this:
    <dbox enabled="false" />
    <udp enabled="true" extradata="0" ip="192.168.1.100" port="4123" delay="1" />
    after that, the game engine starts to receive data but there is no Roll or Traction Loss I don't get it!
    153,703Coins
    There is roll and TL data in the Tuning Center, so likely you need to lower the TC values and perhaps increase the Axis Allocations, though TL should already be 100%.
  20. Jean Paul Andrade
    272Coins
    @noorbeast after giving a good look at the data received by the game engine I realized that there's no really data in Roll and TL the number that shows in the box is just a continuous count up and never stops until it gets to 10 and then resets to 0 and starts again, there's definitely something wrong in the data that the game manager sends, I know there's a lot of people having issues with the DR2 plugin, the latest version to be more specific, do you have any other advice? I really would like to have my DR2 working as it should.
