Showroom DX - Compact Simulator
Discussion in 'DIY Motion Simulator Projects' started by noorbeast, Sep 29, 2014.
  1. T R Para
    T R Para i make stuff up
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    ok thanks. I studied that pic and it looks to be 75mm but nothing to reference it against.
    The mechanism may be here tomorrow and I will see if it can extend that far.
    The one similar to yours is about $60 usd but there are no real specs on it..
    Amazon had one on sale (different model/style ) for $20 :o:
    153,992Coins
    +11,162 / 57 / -2
    I am sure it is significantly more than 75mm, at a guess likely twice that.
  3. T R Para
    Cincinnati, Oh
    2,446Coins
    AC motor, 6DOF
    I think I finally got my head around this. That pivot point on the Tilt mechanism determines the amount of heave available..
  4. Trigen
    Trigen Active Member
    2,891Coins
    This latest heave solution is very interesting. I was thinking of going with SFX-100 but with space constraints i honestly just need a seat mover with heave as you have done for my G seat. Id even be happy with only heave.
    With the Tilt mechanism I suppose also depending on how much it goes up and down it will move forward a bit? Do you really notice it. I do have a tilt mechanism i can scavenge from the DX racer seat im using (not sure if its strong enough) but would you mind pointing me in the direction of yours?
    Ive also been thinking of using a car cross jack (removing the inner rod) and mounting springs either inside or one on each side. Of course the tilt i may be easier to do cheaper but this would go straight up and only cost about 20$ so then its just finding the right spring. What's you opinion of it in relation to the other components?
    Also. What would be a ballpark cost for the base? Ill be incorporating it into a Simlab P1X rig
    153,992Coins
    +11,162 / 57 / -2
    Yes there is some travel through an arc: https://www.xsimulator.net/community/threads/dx-compact-simulator.5866/page-16#post-86702
    But it is minimised and actually a bit useful in how I have surge configured, as that takes advantage of the small for and aft movement the arc allows.
  6. cityparker
    cityparker Member
    125Coins
    2DOF, DC motor
    Its pretty too much!and it is 3dof,I like it.
  7. thewaggy
    thewaggy I am one of the two funny three.
    Austria
    - 19Coins
    2DOF, Arduino, 6DOF
    Interesting Ideas ! good work ! How much did you spend for this ?:cheers
    153,992Coins
    +11,162 / 57 / -2
    Total cost depends on what you count, I owned the race seat and peripherals, but see here for a bit of a break down: https://www.xsimulator.net/community/threads/dx-racer-compact-simulator.5866/page-21#post-108114
    I purchased a $90 welder and $60 drill press, borrowed a grinder and used my old soldering iron, electric drill and jigsaw plus hand tools to build my sim. Most of my DIY compact 3DOF motion sim just bolts together!
    My motion rig cost far less than the quality peripherals that are mounted on it.
  9. headbangersball
    headbangersball Member
    Sales
    914Coins
    Awesome.I haven't been on this site since 2014. You've got my mind working on V2.0. I like the lightweight compact design. My first motion sim one was a bit of a Behemoth
  10. Виталий
    Виталий Member Gold Contributor
    fireman
    Ukraine
    207Coins
    Very cool sim! I read the thread, learned a lot of new and interesting things. You are well done!
  11. pavlo
    pavlo New Member
    28Coins
    3DOF, Arduino
    Thank you Senior for your collaboration. I also like it very much
  12. czgui
    czgui Member
    - 110Coins
    Great compact design, I don’t have tools.
  13. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    Noorbeast, do you still own fanatec pedals v2? Have you ever had oil leak with the shock? I have recently bought v2 and i dont know what oil i should use.
    153,992Coins
    +11,162 / 57 / -2
    Yes I still have the pedals and no I have not had leaks, I still have the light oil that came with the pedals but don't know what grade it is, as the bottle is not marked in any way.
  15. tomkil192
    tomkil192 Member
    Uk. London
    - 24Coins
    ok. Thanks
    I will just clean my one and re-fill with some oil. I have some from my RC cars..
    Pedals are great but i need to get use to the clutch. It feels like old car clutch. I might need to add some damping because i dont like the clunk.
  16. Arihant
    Arihant New Member
    Electronic Enginner
    Mexico
    96Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino, Motion platform, 4DOF, 6DOF
    Great Platfrom, i read completely the discussion and learned a lot!! thanks . im making my own sim platform with wheelchair motors 24vdc 36nm rated torque 60rpm on gear shaft 250w and your desing is perfect for it .
  17. paco
    paco New Member
    - 106Coins
    amazing, I love it, compact and precise, I am looking forward to learning, thank you.
  18. Quang Thuy
    Quang Thuy New Member
    87Coins
    Great, excellent, wonderfull. You are so professional. Compact project, very useful for me to study.
  19. Quang Thuy
    87Coins
    I observe that the most bearing structure is in the seat part. So, can I replace the steering wheel and accelerator pedals with wood?
    153,992Coins
    +11,162 / 57 / -2
    It depends, what is really important is structural rigidity, so you don't lose fine motion cues.
    The other consideration is keeping the mass as low as possible for the upper platform.
    For both those reasons I consider aluminum is a better option than wood, though the latter could work.
