got Assetto Corsa triple screen to work
Discussion in 'Assetto Corsa' started by Krow56, Dec 5, 2019.
  1. Krow56
    Krow56 New Member
    Electrician
    Thunder Bay Canada
    224Coins
    so was no way able to get it running simply thru game setup and Project Cars2 worked no problem, so after some digging was able to find out that by going into documents then into assetto folder-open up the cfg folder then go to video open that file and edit the screen width to 5760, saved it then back into game, now resolution showed 5760 1080 and with game set to triple and full screen rendering off there it was.
    this sorta stuff is outta my comfort zone however learning more all the time :)
  2. Krow56
    Krow56 New Member
    Electrician
    Thunder Bay Canada
    224Coins
  3. Krow56
    Krow56 New Member
    Electrician
    Thunder Bay Canada
    224Coins
    sorry getting used to posting screen shots
  4. RacingMat
    21,006Coins
    Thanks for sharing!
    those setups for triple screen and games can be nightmarish...
  5. HardyG
    HardyG New Member
    North-Rine-Westfalia
    104Coins
    no idea, what you talk about. if you set your resolution with nvidia surround or the AMD Equivalent, you must be able to see and set the resolution in Game. Maybe the point is hard to find, but def. no editing of the ini's nessesary.
  6. Krow56
    Krow56 New Member
    Electrician
    Thunder Bay Canada
    224Coins
    did all of that went thru the steps many times and could never get option to select 5760 res. o went with editing and working good
