race room braking help
Discussion in 'Ready, set, go - Start your engines' started by Coops, Dec 7, 2019.
  1. Coops
    Coops New Member Gold Contributor
    Fitter/Machinist
    Australia
    129Coins
    Hi All, need help with braking response, i have tried adding pitch with surge but the car is slow tor react.need help with settings - if i am going up hill and apply heavy braking i am not feeling this, i need the car to either pitch forward to feel this any help appreciated running amc controller with 6fof.
    154,580Coins
    +11,190 / 57 / -2
  3. Coops
    Fitter/Machinist
    Australia
    129Coins
    I have gone through each axis as per instructions.
  4. Coops
    Fitter/Machinist
    Australia
    129Coins
    I have gone through each axis as per instructions. I have played with tuning centre and reduced numbers for response. platform works well with all axis but need more response with braking.
  5. Coops
    Fitter/Machinist
    Australia
    129Coins
    The surge seems to work fine but i feel the car needs to pitch forward with the braking application when going uphill.
  6. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Hi, you seem to be trying to work all in one DOF, e.g. all your settings are in one column. For a 2dof you should use 2 rows (Axis 1b and 2b in pic below) and then a column for each type of force you are replicating. A bit like the attached picture - this shows only 2 forces, in DOF3 you would add pitch then in DOF4 roll and in DOF5 heave. Bear in mind each row of %'s should add up to a max total of about 130 (technically 100 but 130 is often used to enhance motion)
  7. Coops
    Fitter/Machinist
    Australia
    129Coins
    Ok thanks for the info i will experiment.
  8. Thanos
    Electronics Engineer
    2,917Coins
    The standard simtools mixing is not going to work for simtools. 6DOF Stewart platforms need inverse kinematics math. Simtools has such 6DOF plugin you could try:
    https://www.xsimulator.net/community/marketplace/categories/axis-assignments-plugins.36/
    See how these work:
    These are made by the creator of FlyPT mover btw. You could use the FlyPT mover to handle the 6DOF math and get the motion data from Simtools...
  9. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Oh yes, I missed this is for a 6DOF. Was reading too many threads! Thanos has the answer :)
  10. Coops
    Fitter/Machinist
    Australia
    129Coins
    I have been using flypt mover software 2.8 and will continue as this is now working for me, i will try some games that are not supported yet by flypt and let you know how i go cheers.
