Showroom Project going from wood to steel 2DOF platform
Discussion in 'DIY Motion Simulator Projects' started by dedas, Apr 2, 2014.
  1. grooste_lwd
    grooste_lwd Active Member
    Nederland => Friesland => Leeuwarden
    124Coins
    Works out of the box! LoL
  2. grooste_lwd
    124Coins
    My smc box. Works fine whiote SMCutil :). SAM_0719.JPG
  3. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Looks ok, you will see that the h-bridges (IBTs) won't get hot at all. They give you a lot of h-bridge for the money :grin
    Keep up the good work and post some pictures on the way.
    Good luck :thumbs
  4. grooste_lwd
    124Coins
    i made a nicer/ better one :). This old one fials to cabels to thin, foto is new one. SAM_0973.JPG SAM_0991.JPG SAM_1001.JPG SAM_0985.JPG
  5. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Looks ok now, heavy duty style :thumbs
    keep op the good work. Are you also building the seat right now or first the electronics?
  6. grooste_lwd
    124Coins
    also seat :) .
  7. grooste_lwd
    124Coins
    Allmost raddy for paint en motors en pimping :).
  8. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Hehehe, it looks OK!
  9. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Yeah, got my hand on a Dell server PSU (N870P) (12V/71Amp), moded it to supply a steady 13.5V.
    Works great with the sim, even on heavy load (using the sim with heavy people :grin) :thumbs
  10. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    so after a few years finaly got some time to pick up simracing again.
    Downloaded the new simtools 2.4 (comming from the old 1.3) and upgrading te OS from Windows 7 tot Windows 10 1909 :)
    Dusting of the old 2Dof rig to see if i can get it to work again :grin
    (having some new plans to upgrade from a 2dof to a 4dof rig, but first things first)
    154,370Coins
    +11,179 / 57 / -2
    Keep in mind that the difference from SimTools 1.3 to SimTools 2 in setup is that in the Interface Settings instead of axis defined like this <Axis1> it now has designate grouping for a or b in SimTools 2 for each axis assignment, like this <Axis1a><Axis2a>
  12. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Thanks for the tip! (appreciated) :thumbs
  13. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    This week, after several test runs, the SMC3.0 controller suddenly stopped working. After some investigation, the arduino mini turned out to be fried :(.
    Strange but no problem, I have enough in stock so I flashed a new one and tested everything on the workbench. After the test everything was reinstalled, broken again :think.
    Grrrr now the IBT2 H-Bridge was defective and this caused the aurduino to break. Replace IBT2 and again the Arduino. Now i connected a power supply with current limiting.
    I noticed when I connected motor 2 a short-circuit current started to flow, It turned out that a resistance could be measured between the windings and the housing.
    After I took the motor apart there appeared to be a build-up of carbon of the contacts which caused enough resistance which resulted in a defective H-bridge, cleaned and tested and now everything is working properly again. :)
  14. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    I did not pay attention and had changed the motor connection, result bent steel (witness of the power that the motors with gearbox have):nerd
    154,370Coins
    +11,179 / 57 / -2
    Ouch :eek:
  16. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    I have a strange problem, I am using the SMC3.0 controller (2DOF) V1.0.
    If I use SMCUtils and I move the motor slider (1 or 2), there is nice smooth movement from zero til max.
    When I test with "SimTools Output" and I move roll or pitch there is no movement until about 40% and then it starts immediately. Even if I move the slider in Axis 1 or 2 in Axis Output, there is only movement from 30-35%.
    Anyone any idea? (it drives me banana :think)
    :sos
    154,370Coins
    +11,179 / 57 / -2
  18. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Of course, here are my settings, first SMC3 setup:
    Simtools settings:
    The hardware i'm using is a Arduino pro Mini with 2 x IBT2 h-bridges.
    2 x 350W motors with gearbox
    What I also noticed is that since I use the latest smc3.0 firmware it regularly lost the saved settings. I have a 2nd configuration consisting of Arduino Nano and 2x IBT2. I'm going to test this config with the same motors and software to see if there's something wrong with the hardware.
    Hope somebody can point me in te right direction :(
    154,370Coins
    +11,179 / 57 / -2
    Looks like you are using the depreciated SimTools 1.3, is that correct? If so it is time to upgrade.
    Why do you need axis limiting?
  20. dedas
    dedas Active Member
    IT Manager
    Netherlands
    - 26Coins
    Yes i'm using the old simtools (i'll update my software)
    What do you mean by "Axis Limiting" ?
    (in the last picture i'm moving axis 1 as a example, it starts to move on the given value.)
