Showroom My 3 DOF first time project
Discussion in 'DIY Motion Simulator Projects' started by Petemnz, Sep 12, 2019.
  1. Petemnz
    Petemnz Member
    Sparky by Trade
    Auckland, New Zealand
    60Coins
    After reading thru this site I decided to build my own sim. Settled on a design with the motors driving under the seat front. Built as 2 DOF first and add rear slider traction loss at a later stage. Brought a welder, wish I'd brought one years ago.
    Parts list so far
    Design 3 DOF front of seat and rear slider DIY prices in NZ$
    Software Assetto Corsa (Bathurst AU and Hampton NZ) 1 $ 25
    Motors KS-90WZY J08 -12v-300w 25:1 gearbox 120rpm 2 $570
    Universal Used BMW car universal Zebra car parts $50
    Steel 20 x 20 x 1.6 box 25x25x3 angle AL thread plate Bunnings 20m $ 840
    10k pots ebay $3
    Arduino UNO ebay $6
    Motor drivers ebay Monster Moto Shield VNH2SP30 14a + Heat sink $22
    Power supply used ebay DPS 1200FBA 100A HP $40
    PC AMD 6 core AMD graphics card used Trademe $280
    Used car seat from MR2 free
    New wheel Thrustmaster T150RS PRO Racing Wheel $350
    Used pedals Thrustmaster 3 pedal trademe $60
    Used shifter G29 with usb mod trademe $40
    10mm thread rod M10 Bunnings $10
    Swivels ebay M10 rod ends $ 4
    M8 nuts bolts Bunnings $20
    M10 rod ends 4 Banggood $20
    First time welding, so pretty happy with result. :thumbs
    PC Spec's for those that asked.
    I've been using for 6 months now, very smooth and good graphics IMO.
    CPU: AMD FX-6300 6-core 3.5 GHz processor
    RAM: 8GB (2 x 4GB) DDR3 1600 MHz G.Skill
    Motherboard: Gigabyte GA-78LMT-USB3 rev 5.0 mATX Socket AM3+
    Graphics card: Powercolor AMD Radeon HD 7850 2GB PCS+
    Storage: 2 x 160GB Hard drives for a total of 320GB
    PSU is a 650W unit with two PCIE 6-pin power connectors.
    OS: Windows 10 Pro 64-bit, activated via digital license attached to motherboard
  2. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Went to the wreckers today and removed a drive shaft from a 3 series BMW for my universal - cut to size with hacksaw and welded to steel plate from local hardware store (Bunnings). photo's show trial position , need a hand to find balance point.
  3. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Got the motors today upload_2019-9-28_20-18-49.png upload_2019-9-28_20-19-24.png
    Punched the rivets out of the gearbox and used a hole saw to cut hole for the shaft on other side of gearbox and made into lefthand box. Metal gears looks solid no backlash.
    I should have ordered left and right hand gearbox in hindsight. :)
  4. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Open gearbox - brass gears is a good sign.
  5. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Testing seating position :)
  6. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Deciding on motor position and motor mounts.
  7. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Motors mounted to 3mm angle - will drill holes in frame once final alignment to seat made.
  8. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
  9. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Drilled & tapped M5 bolt into motor shaft to connect to pot.
  10. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Pipe sleeve bolted to motor before welding turning arm. ( Don't do this, it needs to be a key way or you will get to much play, I learnt the hard way).
  11. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Mounting motors and turning arms - checking motion limits, roll 12 deg, pitch 8 deg.
    Not sure if this is normal?
  12. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Dismantle, paint and rebuild.
  13. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Testing wheel and pedals on local track :)
  14. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Finally got back into it, the Monster Moto Shields took 2 months to arrive, lucky I ordered 4 as one was DOA . I suspected as much when the motor moved, even when I had turned all PWM to zero. Luckily the other one worked as expected and I used it to test both motors and pots before changing to a new Monster Moto Shield. All tested ok with SMC3 so setup on simtools demo and LFS once I got the interface working with help from https://www.xsimulator.net/community.
    Below is the wiring setup I used to parallel up chips and increase current handling thanks to another helpful post.
  15. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Simtools setup with Arduino .
    Pic 1 - monster moto - link pins as wiring diagram
    Pic 2 - Simtools Interface setup - Note your com port could be different.
    Pic 3- Old UPS control box came in handy
  16. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Next issue - these couplings have to much play I need to use the key way. (it bent the stainless bolt) I should have known better but was in a hurry to get it all working.
    152,535Coins
    +11,085 / 56 / -2
  18. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
  19. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    Another update after refitting keyed levers and fitting control box to frame.
    Wife testing :)
    Heat sink temps on chips.
    I'll put grommets in holes and tidy up cabling later, but keen to test out first.
  20. Petemnz
    Petemnz Member
    Sparky by Trade
    60Coins
    My test pilot (wife) still seems a bit jerky. (maybe the driver) ;)
