DIY FFB STEERING WHEEL
Discussion in 'DIY peripherals' started by Gilvan Marchiori Araujo, Dec 3, 2019.
  1. Chris_Beeves
    2,196Coins
    Wow, what motor is that?
    I don’t have enough experience to tell, but if the motor is close to those specs my guess is that you’ll be fine.
  2. Chris Malcolm
    Chris Malcolm New Member
    291Coins
    It's looking good so far to me. I reckon that setup will give you decent torque at the wheel. I think the thrustmaster t300 uses a similar size motor and a dual belt pulley system.
    The only thing I'd check is the type of pulley that you have. I use a 5m timing pulley but you could probably get away with a 3m pulley. If you have any smaller, the belt will slip.
    I've googled seeing machine pulley and it looks like you don't have a timing pulley. The Fanatec CSW is the same, I think. You'll probably need to get some "idler" pulleys so that the belt is tight.
    You'll probably be ok using just one bts driver, with the motor that you're using. But if you can, get two, so that you have one spare. They're usually the main part that fails.
  3. Gilvan Marchiori Araujo
    Gilvan Marchiori Araujo New Member
    169Coins
    Guys, follow the progress of my project, take a look, and tell me if it is good, if there is something that is not cool or that can improve, give me tips, my knowledge in mechanics is very good, but in the area of electronics not quite
    the pulleys and structure I will do in my work
  4. Gilvan Marchiori Araujo
    169Coins
    Can you explain to me why if I get 2 drivers would be better? Is it because the arduino divides the "service" between the H bridges? one takes charge of voltage regulation and the other polarity reversal? explain it to me
  5. Gilvan Marchiori Araujo
    169Coins
    so beeves, look that print... the dc motor that i will buy.. its 19.5k rpm not 15k, so i mean 1:16 reduction i will be fine so
  6. Sieben
    Sieben Active Member
    2,241Coins
    It will give around some more then between 300rpm - 400rpm, as also depends on the wheel U got.
    The wheel needs 200rpm. And that's enough. It just should be not less then this numbers.
    8mm thread, better be reinforced with "connecting prolonged nuts". Can check my thread.
    https://www.xsimulator.net/community/threads/arduino-leonardo-sim-wheel.12741/#post-168870
    It devides the amount of current between them in few words.
  7. Daud077
    Daud077 New Member
    82Coins
    Hey can I use a cheap photoelectric rotary encoder
  8. Chris_Beeves
    2,196Coins
    Probably, yes.
    Do you have a link? It would be easier to tell.
  9. umdasu
    umdasu New Member
    62Coins
    Good morning Gilvan,
    brother let you ask. did you complete your steering wheel project? was it worth the cost benefit? how did you do the pedals?
    Obviously I am so wanting to assemble one or buy a used one. your help would be really welcome. I hope you get that.
    thankful
  10. Faisal Nyan
    Faisal Nyan Member
    Just a Maker
    375Coins
    DC motor
    Hello, what PSU specs do you use?
  11. LostiLama
    LostiLama New Member
    17Coins
    Hello i try to make this projekt but my encoder wont work but a normal arduino encoder works i use : e38s6g5-600b-g24n encoder .( thats the part list because i cant post links )
    but im not sure why it isnt working
  12. Chris_Beeves
    2,196Coins
    Do you have pull-up resistors on A&B? That’s usually necessary on those type of encoders.
