FlyPT Mover 3.5.3
  1. pmvcda
    15,384Coins
    Do you see the actuators calibrating? (go up an down 1 time)
  2. F-Zero-One
    F-Zero-One Member Gold Contributor
    derby, derbyshire
    22Coins
    Yes I did
  3. pmvcda
    15,384Coins
    Then they stop right?
    What speed do you have on the serial for the the ESP32? Because in Mover you used 115200.
    In the code sample I posted it was 921600
  4. F-Zero-One
    derby, derbyshire
    22Coins
    #define SERIAL_SPEED 115200
  5. pmvcda
    15,384Coins
  6. pmvcda
    15,384Coins
    Please verify the code on th ESP32. And keep the 2 actuators and serial speed of 115200
  7. F-Zero-One
    derby, derbyshire
    22Coins
  8. pmvcda
    15,384Coins
    Please try the original code with the serial speed at 115200, and 2 actuators
    I posted the other one for Flymen. In your build you have everything like me.
    What is happening is that the actuator moves to the limits and when he reaches it, he think's he's on the opposite side. So he jumps to the other ide until it touches the limit again repeating the error.
  9. F-Zero-One
    derby, derbyshire
    22Coins
    Ok original code 2 actuators and no movement 115200 speed, they did calibrateso they do work but they are not doing the weird movement, however changing sliders does not afffect anything
  10. pmvcda
    15,384Coins
    After calibrating they don't do anything with sliders (heave)?
  11. pmvcda
    15,384Coins
    Try this setup:
  12. F-Zero-One
    derby, derbyshire
    22Coins
    movement
  13. F-Zero-One
    derby, derbyshire
    22Coins
    Ok so now I have movement think my board crashed on that last on
    but both actuators go in same direct regardless of pitch and roll, I was expecting one to go up and one down n roll, lets leave it for tonight, many many thanks, you are doing great things
    Les
  14. F-Zero-One
    derby, derbyshire
    22Coins
    I think we have a winner, Yayyyyy I will test tomorrow brilliant
  15. cfischer
    Colorado
    2,783Coins
    Maybe instead of a manual there could be a quick video. Might save you time and explain things better.
  16. F-Zero-One
    derby, derbyshire
    22Coins
    Now that I have movement I can "see" the relationship between everything, but the issue was I had implemented some code changes for another user, roll back to the correct code and all came good, I will definitely be donating when I get paid, this software and actuator design is awesome!!!!
    is there an elite dangerous plugin for Flypt mover lol joking little.
  17. F-Zero-One
    derby, derbyshire
    22Coins
    I'd be willing to write a manual once I have everything in my head
  18. hannibal
    hannibal Active Member
    4,491Coins
    i am late to the game, but i am very excited to finally get into this area of study.
    u da man @pmvcda
  19. F-Zero-One
    derby, derbyshire
    22Coins
  20. cubexxx
    cubexxx Member
    549Coins
    3DOF, AC motor, Arduino, 4DOF
    Hi, pvmcda, setting the soft start/stop transition times to zero (0) doesn't seem to work correctly, I get a "NaN" on the output connection status, see attched image disableSoftTransitionBug.png
