Tutorial 3Dprint Shim for adding vibrator on Thrustmaster T300 pedals
Discussion in 'DIY peripherals' started by SoftKitty, Dec 18, 2019.
  1. SoftKitty
    SoftKitty Member
    Engine engineer
    Nantong, Jiangsu, China
    - 140Coins
    AC motor, 6DOF
  2. SoftKitty
    SoftKitty Member
    Engine engineer
    - 140Coins
    AC motor, 6DOF
    Next instead of drilling holes on the pedal lever, I decided to design a new pedal shim to bolt the motor on.
    The first design was almost identical to the original(black) but added with a M6 mount.
    Later before I made another one for gas pedal, I made some modifications:
    1. weight reduction
    2.harness guide
    I forgot to take pictures before I assembly them, this is the model image, of course I will upload the stl file later in this tread.
    This is the final product.
  3. SoftKitty
    SoftKitty Member
    Engine engineer
    - 140Coins
    AC motor, 6DOF
    Here are the stl files
    shim1 is the first edition,
    shim2 is the one with new pattern and harness guide.
