FlyPT Mover 3.5.3
  1. pmvcda
    15,448Coins
    Thank's! I will take a look.
    Should be a division by zero... :roll
  2. pmvcda
    15,448Coins
    @cubexxx , thank,s again!
    Problem is solved for new build. Also found a mix in the soft transition of the outputs and source, besides a wrong saving of the setup.
    So 3 bugs solved.
  3. cubexxx
    cubexxx Member
    551Coins
    3DOF, AC motor, Arduino, 4DOF
    Wow, you're fast sir! And you're of the rare species that seems to appreciate when someone shows them their bugs... I will gladly report all bugs I may find in the future:D! I Thanks you for the very nice software you're sharing freely!
  4. F-Zero-One
    F-Zero-One Member Gold Contributor
    derby, derbyshire
    22Coins
    Hello there, installed fly pt on game machine with rig and the rig is good etc, but I cant get lfs plugin to connect it just stay yellow, any ideas? fire wall turned off cheers
  5. pmvcda
    15,448Coins
    Run some laps in lfs to make lfs generate some needed Giles.
    Then open the Readme inside the Mover folder. There's a small info on how to enable telemetry for lfs.
  6. F-Zero-One
    derby, derbyshire
    22Coins
    I went back to 2.7 and it works, well it connects
    no data though
    when edit file it reverts to 0
    OutSim Mode 0
    OutSim Delay 1
    OutSim IP 127.0.0.1
    OutSim Port 0
    OutSim ID 0
    OutGauge Mode 0
    OutGauge Delay 1
    OutGauge IP 127.0.0.1
    OutGauge Port 0
    OutGauge ID 0
  7. F-Zero-One
    derby, derbyshire
    22Coins
    got it!!!!
    THIS IS COOL!!!
  8. F-Zero-One
    derby, derbyshire
    22Coins
    but 2.8 does not work for me
  9. cubexxx
    cubexxx Member
    551Coins
    I've seen that some want to use the simfeedback controller (arduino lenoardo) with the flypt mover. While the protocol isn't open, there is an open interface to create providers. So I just created a provider in simfeedback that reads from a mmf (memory mapped file). By using the mmf-output type in mover I can send axis data to simfeedback which then sends it to its own controller. I can post it here if there is demand for it.
  10. wannabeaflyer2
    london uk
    8,346Coins
    Hi @pmvcda im having cant see the wood for the trees moment , working with kartkraft on my 4DOF sim and making good progress , just bought No Limits 2 full version and thought id try that in VR mode with the platform .. I may have missed it and if so can i ask you or any other member to point me to the post page, but cant seem to see how to set up Communication to Mover ref IP config data and port number settings ?
    i have the mover NO LIMITS 2 source module selected and can see the IP address data but as this is a Steam version im not immediately seeing how i can set up NL2 to match the settings in mover
    i looked at Readme file supplied with Mover but dont think i saw No Limits in there ?
    Ran No Limits 2 and Opened Mover module Pressed Connect but no data being updated in Source module ? Cheers
  11. wannabeaflyer2
    london uk
    8,346Coins
    Ok i found a reference to this in post page 28 or thereabouts but i think its Simtools related, what im hoping for a direct Connection module to No Limits 2 if that's possible ( still not got off my butt regarding getting confortable with using Simtools : -( ) sorry guys
  12. pmvcda
    15,448Coins
    Hi, not at home right now, but when starting no limits (demo doesn't work), do you see a message of the telemetry server?
    Try to put your pc ip instead of the default one.
  13. wannabeaflyer2
    london uk
    8,346Coins
    Hi @pmvcda no rush Good buddy , theres other stuff in life that needs doing so can wait , no problem .. just for background info ,
    Selected CMD in dos window to run IPCONFIG and system reported my IP address Ok
    Opened Mover No Limits source Module and changed the default IP to match my system IP , Left the Default Port as 15151 and ran No Limits 2 ( Full version) but still not seeing any data when simulation is running ... like i said , no rush you'll answer when you can , so im happy with that :) Cheers
    Opp's forgot to mention did not see message referring to telemetry Server anywhere on screen display ( but message in No limits 2 title bar said read only ??
  14. pmvcda
    15,448Coins
    Really sorry for taking so much time.
    With so many games, forgot about what is needed here.
    You need to go to the launch options in steam and start nolimits with --telemetry --telemetryport=15151
  15. wannabeaflyer2
    london uk
    8,346Coins
    All sorted now thanks for the fix , i now have motion on three simulation programs , your a busy guyn and still find time to get our issues sorted , im just saying big thanks for getting me up and running again ..., Tuning time now LOL Cheers @pmvcda
  16. BrassEm
    BrassEm G-Seat + SFX100 Builder Gold Contributor
    NE of YMML
    1,102Coins
    DC motor, AC motor, 4DOF
    G'day,
    Is anyone running FlyPT Mover on a second PC?
    I have DCS working with Simtools GameEngine on PC 19.190.26.2 to GameManager on PC 19.190.26.5
    I cannot get DCS to export.lua from .2 to Mover on .5
    .exe and ports opened on firewalls.
    Thanks,
  17. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    @pmvcda
    I think I was wrong willing to construct flaps and gear noise in relation to air speed.
    While in theory it makes sense to make it smaller as the air speed decreases, in reality, I am observing quite steady noise amount.
    Please observe the noise increasing in the descent phase as flaps and gear are getting deployed.
  18. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    @pmvcda , @Dirty has mentioned a Perlin noise as something which could be a suitable solution (better than a simple sine) to reach more realistic effect for flaps, speedbrakes or landing gear noise.
    What do you think about it ?
  19. hexpod
    berlin
    7,770Coins
    DC motor, 6DOF
    Posting here some so called “short finals” which means more or less last 200s before touch down. @Dirty please correct me if the terminology is wrong.
    Two Embraer 190 and two B737 experiences.
    While in Embraer you will notice very distinctive noise increase while landing gear goes down, in Boeing example the moment is less obvious probably due to more turbulent atmosphere on the day.
    Feel free to comment.
    Here is Embraer :
    Here is Boeing :
  20. SeatTime
    Is this noise/vibration something that you will pump into a transducer (buttkicker etc), or will you try to have your actuators reproduce this?
