value1
Raceroom Racing Experience Plugin 2.0.7.1
SimTools game plugin for Raceroom Racing Experience
  1. Foehn
    Foehn Member
    Race ; Mechanic ; Simulation
    3Coins
    3DOF, SCN6
    ok, what do you suggest ? (re-install Simtool ?)
    @Kranky Pantz what version of the plugin do you use ? 2.0.7.1 ?
    I have the 2.0.7.0
  2. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    the actual Build is 0.9.0.0915
  3. The Iron Wolf
    The Iron Wolf Active Member
    Bellevue, WA
    375Coins
    3DOF, SCN6
    @value1, big thanks for the plugin :) works great!
    A small ask, would it be possible to avoid strong punch upon entering session/menu?
    Attaching my min/max values (as of 01/20/2020) and a small calculator to leave room for headroom for others to try.
    • r3e.zip
      7.2 KB
      544
  4. Michael Jeffries
    Michael Jeffries Member Gold Contributor
    485Coins
    Motion platform, 4DOF
    What kind of motion rig do you have iron wolf?
  5. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    prosimu t1000 3d0f SCN6 dyadic. Min/Max might be useful for others as well though.
    I have 0 issues with raceroom so far, it is less precise/detailed than rf2, but very enjoyable. The only thing I don't enjoy is this huge punch on entering menu and track.
  6. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    Another request: Since game currently does not implement cooldown lap, would be nice if motion is stopped after s/f line crossing in the Race.
  7. FrancescoRoberto
    FrancescoRoberto Member
    Italia
    86Coins
    I'd like to know if the plugin is ok to RACEROOM DTM experience 2015 too.
    Best Regards
    Francesco
  8. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    it's the same for me for entering menu and track and some time I feel some jerk on surge (no linear flow)
  9. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    and yesterday, i played with Assetto corsa to compare and it's very better with more details
    I've the same T1000 like you
  10. FrancescoRoberto
    Italia
    86Coins
    Thanks, I like the DTM cars so I find race room like a game which there are these cars in.
    But I understand that you prefer Assetto corsa like simulation game.
    Best Regards
  11. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    You are right, the DTM cars are beautiful in R3E
  12. The Iron Wolf
    Bellevue, WA
    375Coins
    3DOF, SCN6
    I did not try, but someone on S3 forum mentioned that cars that did not receive physics update, still have oscillation issues.
    @FrancescoRoberto You can also experience DTM in rF2 (URD T5 with skin pack). It doesn't look as good as R3E, but physics are way more detailed (especially in terms of motion), and cars are fragile, lose doors, wheels, wings. But, rf2 is not everyone's cup of tea :) hopefully R3E DTM will get update soon
  13. nornesnaj
    nornesnaj New Member
    Netherlands, Zelhem
    125Coins
    I cannot get the plugin to work. can somebody please advise.
    simtools gamemanager is not recognizing that raceroom is running.
    are there some settings in raceroom i need to change ?
  14. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Nothing to change into the game, what release of plugin and game have you ?
  15. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    I again, I tested just now with the lastest release downloaded of r3e and it's works
  16. nornesnaj
    Netherlands, Zelhem
    125Coins
    I use Race Room Experience build 0.9.0.0937 (treid both 32bit and 64bit)
    RaceRoomRacingExperience_Plugin.2.0.7.1
  17. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Same release for r3e and plugin 2.0.7.1 for the pluging on my side (I'v not the latest release)
    If you have other telemetry software opening (fanalab, dash, etc..) in the same time, close them and try again
  18. nornesnaj
    Netherlands, Zelhem
    125Coins
    still not working closed all other applications
    only simtools etc. and raceroom. still nothing.
  19. Foehn
    Foehn Member
    3Coins
    3DOF, SCN6
    Simtool work with another game ?
    Try to remove the plugin and add it again.
    Check into sim manager if the green color is activated with "plugin installed"
    151,461Coins
    +11,038 / 56 / -2
    It may help if you also post pictures of all of your settings.
    Just checking the obvious, but to be sure can you please confirm you are using the
    pro version of SimTools, do other games work fine?
