Showroom My diy motion rig, 4DOF with surge.
Discussion in 'DIY Motion Simulator Projects' started by Bajer, Dec 23, 2019.
  1. Bajer
    Bajer New Member
    172Coins
    A666ACEF-9D79-45D0-874A-22FBE8519263.jpeg F4769BCD-50F9-41DE-BF4C-4D5EA323DFEA.jpeg 60F66824-92FF-4780-9F86-95358876E797.jpeg I’ve finally got my parts for my 4dof with surge. After some work I’ve managed to get the platform ready to mount my rig which is a sim lab GT1 evo. The platform consists of 750w AC servo motors attached to custom actuators, the control is via AMC servo controller from Thanos. The slide rails are 15mm linear bearing blocks with one block in each corner of the rig, rails are 50cm long which allows me around 35cm of travel.
    Now comes the test phase, any help or info would be welcome.
    • Like Like x 5
  2. lilted86
    lilted86 Member
    Malaysia
    489Coins
    Custom actuators? Keen to share some details?
  3. Bajer
    Bajer New Member
    172Coins
    They are made with 1605 ball screw and are 150mm travel. I basically went with the required specs of the sfx100 kit but with 150mm travel.
    I went with a flange to take 80mm motors instead of the 90mm. The motor specs are virtually identical between the 2 sizes. These are also designed for push and pull unlike the sfx actuators.
  4. Bajer
    Bajer New Member
    172Coins
    A08DB48B-415D-4B1D-94B9-F3F7D56B8665.jpeg 788FD293-D4E3-4702-B75A-62F04905478F.jpeg 74912345-BC0B-4042-BCC7-3C6E27F06D8B.jpeg 00373702-C7A7-4B00-B4F9-45F2348AF7A1.jpeg Controller and emergency stop button ready to go.
    Next I need to do a bit of cable management before I can start testing the platform.
  5. Paul Shortland
    Paul Shortland Active Member
    Northampton - UK
    317Coins
    2DOF, AC motor
    Looks like a neat surge solution, I have the same rig and standard sfx-100s. How much did you need to spend on the extra profile and fittings?
  6. Bajer
    Bajer New Member
    172Coins
    The profile was about £300 with fixings, the rails and guide blocks were about £200.
    I’m a bit afraid to total up complete costs
  7. Bajer
    Bajer New Member
    172Coins
    E3485284-2611-4347-A032-013B0431F44F.jpeg D073D6B5-16D7-4961-A5D7-BB6F516B6B8A.jpeg 517656FB-8679-499F-B111-DE10A2972F98.jpeg I did a bit of temporary cable management so I can start testing.
    Once everything is finalised I will tidy up the cabling and hide as much as possible and put the motor drivers in a cabinet.
  8. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    Understand the adding up fear, I stick with ‘just over £1000’ for mine :grin
  9. SoftKitty
    SoftKitty Member
    Engine engineer
    Nantong, Jiangsu, China
    - 140Coins
    AC motor, 6DOF
    The slider and push rod are very clever material choices, very referable if I upgrade mine to have surge or sway movement, I think I can control the cost within $150 in my country.;)
  10. dododge
    dododge Active Member Gold Contributor
    854Coins
    BTW JCL Sim Racing sells a kit for the same sort of surge table but they want 2500 € just for the profiles and rails (without any actuators), so you're doing pretty good by comparison.
    I've been daydreaming about a similar surge setup for my rig for a couple weeks, after seeing the JCL system in a SimRacingGarage video.
  11. Bajer
    Bajer New Member
    172Coins
    Yes, this should work out much much cheaper.
  12. Bajer
    Bajer New Member
    172Coins
    First test complete, now to install some plugins and test some other sims.
    How many coins do i need to be able to download a plugin?
  13. Paul Shortland
    Northampton - UK
    317Coins
    2DOF, AC motor
    You need 250 to buy a 1 week download package and then each plugin you download costs a further 10. If in a rush I think there is a pay money for access option too.
  14. Bajer
    Bajer New Member
    172Coins
    Thanks, I'll purchase a download package. Is there any limitations to the 1 year package?
    154,502Coins
    +11,184 / 57 / -2
  16. SvenRS2
    SvenRS2 New Member
    Cologne, Germany
    - 235Coins
    AC motor, SCN5, SCN6, Arduino, Motion platform, 4DOF
    Nice project! May I ask what slide rails and guide blocks you are using and where you have bought them?
  17. Bajer
    Bajer New Member
    172Coins
    I used Hiwin heavyduty 15mm rails and rail blocks, there are cheaper alternatives available but i didn't want to risk anything failing. They are quite common and can be found from various suppliers, I got mine from Alibaba.
  18. Bajer
    Bajer New Member
    172Coins
    I’ve had a bit of time with the rig now and am having a blast
    Still needs some tweaking to calm down any collisions but I guess it adds to the immersion. F17FBC88-6BC3-45BA-B09B-F26D405D7418.jpeg 6EBE1274-D9D7-40A0-8703-5245F43A5E41.jpeg
  19. Geoff McIntyre
    Geoff McIntyre Member
    236Coins
    This really looks the business. I m really interested in the 150mm travel with the 80 series motors. What size of profile did you use? Do you have any links for the custom parts you used??
  20. gigi
    gigi Active Member
    919Coins
    2DOF, JRK, 4DOF
    Hallo Bajer
    Congratulations first and foremost for your project, really very refined and cured.
    I too would like to make actuators similar to the SFX-100 but which have 150mm range instead of 100mm and are push and pull and not just pull
    I ask you if you can kindly share what is necessary to make the actuators with 80mm motor (I suppose they are).
    I would like to understand what are the different parts to make and buy compared to the sfx-100 project
    Thank you
