2 DOF - Wipermotor - Arduino - Monster Moto Shield
Discussion in 'DIY Motion Simulator Projects' started by Wixx65-x, Jan 1, 2020.
  1. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    I started my first 2DOF.
    I already had racing cockpit so i made a platform.
    I use two 12V wipermotor and design this: 81304031_2496328737245935_7361772385717977088_n.jpg 81353525_976424952739581_4964179426133671936_n.jpg
    To control, an old arduino MEGA and Monster Moto Shield 81789147_2394394660821772_6717209304824283136_n.jpg
    The next step: try to control 1 motor
    I will update my post and come back probably with some questions :D
    Wixx65-x
  2. RacingMat
    21,039Coins
    good job! Aluminium looks nice
    don't hesitate to reinforce your wiper brackets! any play (under stress) will decrease your precision
  3. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    Aluminium looks nice but it's a little bit expensive :( . (25€/m but without welding :D)
    Yes, i will put a bearing in front of each motor
    To reduce stress, they are near to the feets
  4. SoftKitty
    SoftKitty Member
    Engine engineer
    Nantong, Jiangsu, China
    - 140Coins
    AC motor, 6DOF
    aluminium bar costs 25euro per meter? my god no way!
    In my place silver 4040 profile is 25rmb/meter
    the black anodized one I used in my project is 28rmb/meter
    can't call mine a cheap solution any more...
    PS: 1euro=7.8rmb
  5. RacingMat
    21,039Coins
    ha ha! in china maybe :)
    but in France, 40x40 is around 9€ to 14€
    and 40x80 around 25€ indeed :confused:
    je parlais de renfort du support : de l'équerrage pour éviter qu'il plie.
  6. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    Yes.. But very polyvalent for future update like deported handbrake or whatever
    Je vais mettre une nervure aussi pour augmenter le moment quadratique.
    La partie mecanique je ne me fais pas de soucis, je fais une base simple que je vais amélioré.
    Je préféré valider l’électrique avant :D
  7. RacingMat
    21,039Coins
    yes, you have to add inertia with sides added to the bracket
    c'est cela, il faut ajouter de l'inertie
    voir dans mon tuto le renfort latéral du support
  8. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    Je vais faire qqc comme ça oui, avec les profilés alu c'est tres simple de faire des renforts.
    Pour l'avancement:
    Je viens de récupérer mon deuxième moteur d'essuie glace.
    Je m'inspire beaucoup de ton tuto et ta chaine Youtube.
    Hier j'ai nettoyé, isolé et fait fonctionner le premier moteur.
    Il vaut mieux utiliser la petite ou grande vitesse ? De tout ce que j'ai lu, la grande vitesse est préconisée.
    Merci
    Wixx65-x
  9. RacingMat
    21,039Coins
    in english please! ;)
    high speed is recommanded indeed.
    don't forget to isolate the ground!
  10. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    Hi and happy new year!
    Some news:
    -I have now isolated the ground for the two motors.
    -The Home made joint is ok
    -The motor support are ok (they will never move :D : 120*120*6mm of steel)
    -Munster moto shield and Arduino too.
    82075455_1467713016720139_8513760482262253568_n.jpg 82534137_462186767808885_3387011725021675520_n.jpg 82534139_850255858766277_6785294144307724288_n.jpg 82955170_2524019027872590_1597314250236231680_n.jpg
    I hope first try with only chassis for next week.
    i need to tcheck how SMC 3 work with SimTools before launch.
    I'm scared for the first test : how it will react ahaha
    Motor are blocked for 180° max ?
    Have a nice Week end,
    Wixx
    151,467Coins
    +11,038 / 56 / -2
    I am looking forward to your update test.
    Physics dictates that effective torque utilisation drops of rapidly with anything more the than about 40° up and down, so about 80° max movement
  12. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    Ok thanks! In few post i read the reason :)
    Now the mechanical part is pretty ok. I need just to improve my connecting rod.
    Some 3D printing for esthetics.
    82144981_1060019491002459_5757254401584529408_n.jpg 82343952_611179256117621_6563483208300625920_n.jpg
    Next step, Simtools.. :D
  13. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    Some bad news...
    Impossible to move the motors with SMC3 Utils...
    Port COM ok,
    But nothing move.
    i use a copy of arduino mega... so I will try with an official arduino uno
  14. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    Hi!
    It's better with Arduino Uno !
    i can move the motor 1 but only in one direction, and it moving without manuel order..
    Motor 2 has moving but now no, and only in one direction too..
    If you have an idea...
    Thanks,
    Wixx65-x
    151,467Coins
    +11,038 / 56 / -2
  16. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    Hi!
    Some great news are comming!
    First test are made on rFactor with pitch and roll (without seat) and reacting great!
    Video is comming.
    now i have to test with seat and adjust parameters. :D
  17. Wixx65-x
    Wixx65-x New Member
    Gironde, FRANCE
    118Coins
    Hi
    a video is better than words...
    some questions:
    -For limiting the rotation of motor it's in simtools with axis limiting ?
    -how to be more reactif ? If limiting rotation is use axis limiting, so i will deplace motor near to the joint.
    -My PC is almost dead... i will made one. how to use my simtools licence in the new pc ?
    What do you think about my 2DOF ? :D
    Wixx65-x
  18. noorbeast
    151,467Coins
    +11,038 / 56 / -2
    Axis limiting does limit the range available, mainly for things like SCN actuators, which will be damaged if the go too far. However in your case I think you need to refine your motion profile, in particular using lower values in the tuning center, which will limit the range of movement and also make the movement far more responsive, see here for refinement tips: https://www.xsimulator.net/community/faq/steps-to-create-a-motion-profile.228/
    You have a limited number of SimTools reactivations, so you just install SimTRools on the new PC and register it as you normally would.
  19. Retro77
    Retro77 Member
    Nurse Practitioner
    Canada
    58Coins
    How to you find the Monster motor driver so far. Heat an issue?
  20. WS786873
    WS786873 New Member
    71Coins
    I'm also in China. I'm going to make one, but I haven't got a clue. Can I exchange it
