Motion Simulation Software SimTools SimTools v2.6.1
SimTools Release Version
  1. RacingMat
    21,080Coins
    i'm in the process of installing Simtools 2.4 from scratch :)
    in the download section https://www.xsimulator.net/community/marketplace/motion-simulation-software-simtools.63/
    the documentation link send to the old documentation (the old "quickstart guide" I wrote many years ago and other documentations)
    it should send to :
    https://simtools.us/wp-content/uploads/2019/06/SimToolsUserManual-v2.4.pdf
    the pdf looks wonderful! :thumbs I'm following it dutifully
  2. RaceRay
    Hamburg, Germany
    23,884Coins
  3. RacingMat
    21,080Coins
    Perfect! @RaceRay
    Please some more typos to correct in the email sent
    ► error 404
    please add "s" at the end of the url
    should be https://simtools.us/licenses/
    ► on the next step, on the website simtools.us, the link goes to old documentation
    yours
    Mat
  4. RaceRay
    Hamburg, Germany
    23,884Coins
    Thanks mate. I've fixed the link in the mail.
    @yobuddy Please take care of the link on simtools.us website and change it there as well.
    Cheers and Happy New Year, guys.
  5. Mu-KwangKim
    South, Korea
    - 689Coins
    @yobuddy hi. bro. Perhaps... When do you think the country setting problem will be solved?
  6. yobuddy
    51,516Coins
    Hi @Mu-KwangKim,
    I have had allot of reports that its fixed in v2.4 (and one that its not lol)
    Have you done a clean install with v2.4 and tested it out buddy?
  7. Mu-KwangKim
    South, Korea
    - 689Coins
    I did a fresh install but it's still the same. (Screen is also cut a bit ...)
    Surely...Reinstall Windows??
  8. Arazok
    Arazok Member
    Computer scientist
    783Coins
    153,691Coins
    There is a limited number of SimTools reactivation, so that should not be an issue, and SimTools itself does not use a huge amount of computer resources, but some games do.
  10. Arazok
    Arazok Member
    Computer scientist
    783Coins
    Thanks noorbeast.
    Games are not the problem. as I use the Playstation4.
    Is there a tutorial or guide, how to move from one PC to another and transfer Simtools and all of its configs ?
    153,691Coins
    You can backup SimTools to a zip file: https://www.xsimulator.net/communit...thout-loosing-your-profiles-and-settings.160/
    Then re-register SimTools: https://www.xsimulator.net/community/threads/how-to-register-simtools-2-0.9720/
    Then unzip the backup to C:\Users\your_user_name\AppData\Local\SimTools
  12. Arazok
    Arazok Member
    Computer scientist
    783Coins
  13. yobuddy
    51,516Coins
  14. Mu-KwangKim
    South, Korea
    - 689Coins
    What screenshot?
    Is the menu cut off?
  15. Mu-KwangKim
    South, Korea
    - 689Coins
  16. Mu-KwangKim
    South, Korea
    - 689Coins
    I just reinstalled Windows. :)
    The result is the same. OTL...
    Even in version 2.4 ... Games that support UDP must change their country settings.
  17. Arielnac
    Arielnac Member
    Argentina
    240Coins
    Hi.
    I am using this version of simtools and it works excellent. The only mistake it has is that every time the system restarts and the game engine is reloaded, the output type must be reset as "rotational" since it appears as "linear" even if the save option is used.
  18. yobuddy
    51,516Coins
    @Arielnac,
    Is it just Axis 3, or do all of them do that?
    I'm sure I can fix it buddy!
  19. Arielnac
    Arielnac Member
    Argentina
    240Coins
    Hi. It does it in all axes. In the photo select rotational manually. I have to do it every time I restart windows because the difference in the response is subtle but notorious
  20. yobuddy
    51,516Coins
    I'll get it sorted this weekend buddy!
