FlyPT Mover 3.5.3
  1. pmvcda
    15,452Coins
    Traction loss. (putting it here for my reference, but also for others)
    In Mover 2.9 we are going to have some new filters, and also going to loose some useless ones.
    On of the new is the CUBIC filter.
    It's based on the cubic functions.
    So how does it work?
    In the x axis we have the speed of rotation of a car in a game
    In the vertical axis we have the rig rotation
    So if we have a left rotation to the negative X, we turn the rig left, same to the right.
    The particularity is that we have a dead zone where nothing happens and from there it increases exponentially.
    In Mover we can define any cubic finction based on:
    y=a*x^3+b*x^2+c*x+d
    So the use of that filter is CUBIC(VALUE;0.000008;0;0:0)
    Is defining the above graphic, being the 0.000008 the value of a.
    Lower the number, larger the dead zone.
    Since we are stretching the response, we can use a logistic with this filter to make it fit inside the rotation range of the rig.
    For traction loss we use the 3rd degree, but I give the chance to play with the cubic functions by allowing the change of the other parameters.
    There's a CUBIC3, just with the 3rd degree to make calculations faster.
  2. cubexxx
    cubexxx Member
    551Coins
    3DOF, AC motor, Arduino, 4DOF
    There seems to be a bug for the "out of range" message when the value is set to -1:
    It definitely isn't out of range, values -1.001 and -0.999 work. It only happens with the exact value of -1.
    Small feature request: I'm using multiple poses simultaneously, would be nice if one could assign names to them (instead of the default "IDx")
  3. pmvcda
    15,452Coins
    Yes, those IDx are messing it all. I will look at it.
    That -1 is strange...
  4. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    3DOF, DC motor, Arduino, 6DOF
    This is where I put it:
    I attached the config file in case there is something I did not understand.
    Simtools seems ok:
    The connection is yellow and all values stay at zero.
  5. pmvcda
    15,452Coins
    Are you using SimTools to get the data?
    Try using the Mover source to access directly to Dirt Rally.
    And is it Dirt 1 or 2?
  6. pmvcda
    15,452Coins
    You have port 4123 in your setup file. Try change the port to that number in the Dirt source
  7. cfischer
    Colorado
    2,783Coins
    You sir, are a bad ass.
  8. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    You were right! It moves! Thanks.
    I was using the 20777 and it was not working.
    Now, to DCS!
  9. pmvcda
    15,452Coins
    Well, new version is going to take some more days...
    My laptop died this aftertnoon.... Rip
    Got the drives out and everything is there. Had some backups also.
    It was already the second motherboard, but this time I want a new one...
    Hp omen, Lenovo y510.... Wich one...
    • Optimistic Optimistic x 1
  10. cfischer
    Colorado
    2,783Coins
  11. Pierre Lalancette
    Tech Artist
    Quebec, Canada
    8,044Coins
    Hello, me again.
    Testing DCS. Not working of course. Wondering what I am doing wrong.
    Only put the Export.lua file in user-saved data- dcs (replacing the one already there).
    No connect button, I did start on the DCS module. It turned yellow.
    No value in the DCS module. All stay at zero.
    Maybe I am not compatible with UPD module? What does it stand for?
  12. pmvcda
    15,452Coins
    Hi, there's something wrong with the dcs source. I prepared an old pc to look at the code and maybe make a build with that corrected. Let's see if I can make it tonight.
    Meanwhile, I bought a new laptop, but delivery preview is only for day 13....
    Got a Lenovo y740 with an rtx 2070. Think it's enough to play :)
  13. cubexxx
    cubexxx Member
    551Coins
    Hi , I have a question about the "Extra" value and the Center of rotation for 3Dof with 4 Linear-Rig.
    I have defined 2 similar rigs (ID1 and ID3): extra.png
    The difference is the "Extra" and the z-value of the center of rotation. In my opinion both rigs should have the exact same motion, as the center of rotation is in the same point in space, the mounting points of the actuators should have no influence, as the connections are completely rigid. But the motion is different (pitch 0.3 deg):
  14. pmvcda
    15,452Coins
    Hi, I'm going to take a look today.
    At first sight something seems strange.
  15. hexpod
    hexpod http://heXpod.xyz
    berlin
    7,770Coins
    DC motor, 6DOF
    @value1 , @Dirty , @pmvcda ,
    How about making an unified lua DCS script to make it work for Simtools, Nutkicker and Mover in order to not get totally confused what’s go where ?
  16. Dirty
    All the way up front.
    7,957Coins
    That's possible. At least from my perspective.
    Back when I started I made my software compatible with BFF, because that was the only one I knew. I might as well use any other "standard". Then again, in DCS it's only a single file to copy.
  17. bbbkada
    bbbkada New Member
    109Coins
    what about formatting the LUA output as a JSON String, so that the receiver can pick it's data in a more controlled way.
    Removes formatting problems and makes it readable by humans.
  18. Dirty
    7,957Coins
    Probably not a bad Idea. Right now, I have an ugly function called ChopParseAndPackage(string) that reads the incoming raw data string and pushes the parsed values into their processing pipelines. If the data came in as a .json string this might be handy.
    Do you know enough LUA to do that? Is there something like a Convert.toJson(MyDataStruct) function in LUA?
  19. bbbkada
    bbbkada New Member
    109Coins
    there is lua json libraries available, ex. https://github.com/rxi/json.lua
    otherwise you can just format string manually within lua,
    instead of today just send data as space separated values...
    <value1> <value2>... , simplest form becomes
    {label1:<value1>,label2:<value2>}
    or if you wanna make it more advanced
    {heave: {x:<value1>, y:<value2>,z:<value3>}, yaw:{...}}
    and so on, dont know the values sent but you can build the strings manually since the lua only builds the string and doesn't have to interpret any json.
  20. pmvcda
    15,452Coins
    Found the bug. Will be corrected in 2.9.
