Sim 3 DOF 24V
Discussion in 'DIY Motion Simulator Projects' started by Overclockersmania.it, Jan 4, 2020.
  1. Overclockersmania.it
    Overclockersmania.it Member
    Cagliari, Sardinia
    20Coins
  2. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    One goal is to have an adjustable seat, it is ease of access. Knowing how to weld metal, the structure will be made of steel. I chose rectangular tubes 40 by 10 and 20 by 10.
  3. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Another requirement would be to create a frame where the steering wheel pedal and the screen move together. I tried projects with fixed runner and I didn't like them.
  4. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
  5. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Here are the photos of monitor, steering wheel, pedals, seat structure :
  6. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    This is the frame for the third movement. The three engines and electronics will be fixed. The third motor is fixed between the v-bars.
  7. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    in these images you can see the platform on which the simulator runs (yaw, extra movement).
  8. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    In these images they show the steering wheel holder that can be adjusted in height. The frames are finished.
  9. RacingMat
    21,081Coins
    good work!
    the motors (url link) looks sturdy! what speed and torque did you choose?
  10. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    It's a bet. Dependent on the levers of your simulator, I took 40: 1.
  11. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    The doubt is about the durability of the mechanical parts, it seems that they have a good locking torque.
  12. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Engines are the first to arrive !!!!
  13. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
  14. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Next weekend I will try to assemble them and create the arms. They will be 6 cm long from hole to hole.
  15. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    the third engine is one of a truck wiper found at the car wrecker, in the photo the modification to have the output shaft for the potentiometer
  16. Overclockersmania.it
    Cagliari, Sardinia
    20Coins
    Realizing the parts so that everything is in axis took time, and a lot of filing !! Even if I use an articulated joint, these potentiometers are delicate.
