Wagnard
Elite Dangerous Horizons/Odyssey Plugin (XML edition) 4.2.2.0 Pointer update
  1. Wagnard
    Wagnardsoft
    Canada, Quebec, Mirabel
    5,238Coins
    Check in the plugin folder if there is a wow64ext.dll file; if so, backup it and remove it. Do not remove the one in the Simtools directory.
    Usually this kind of error is caused by that.
  2. kev b
    kev b Active Member
    Academic Lecturer - Electrical Engineering
    Swindon, UK
    929Coins
    3DOF, Arduino, Motion platform, 6DOF
    Hi guys - yep, the patch from ED today to 'fix' issues in yesterday's game update broke the moves for us again (damn - sometimes small patches dont have any affect on motion).
  3. Wagnard
    Wagnardsoft
    5,238Coins
    Will try to fix this after work. Shouldn't be too hard to fix.
  4. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    @Wagnard - I forgot to add. I checked those 'spurious movements' I started getting. Its a dodgy potentiometer on my rig on one motor (which I've now replaced). No code issues (as if - eh)
  5. Wagnard
    Wagnardsoft
    5,238Coins
    Thanks, I prefer that :)
  6. Wagnard
    Wagnardsoft
    5,238Coins
    On my way home, will update XML soon (less than 2h if all goes well).
    Here it is. As usual a confirmation is nice ;)
  7. Wagnard
    Wagnardsoft
    5,238Coins
  8. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Hi @Wagnard,
    changed the xml data for patch 1 and we are back to full operation, ship and srv checked. All working well - (just one hex increment in offset 0, lol). Many thanks
  9. Benji85
    Benji85 Member Gold Contributor
    851Coins
    Hey man thanks for your efforts on this again. I'm having the same problem as last time where it wont let me download the plugin even after logging in and having coins etc.
    "You do not have permission to view this page or perform this action." --777 coins in balance
    Would you be so kind as to just post the updated offsets for me? That worked great last time.
    Many Thanks
    Ben
  10. Benji85
    851Coins
    Woops I just saw you posted them before! Many thanks testing now!
    Edit
    Seems all good many thanks man
    Only thing is the bloody yaw axis on my t16000 is playing up again so have to return it and get another which means no gaming tomorrow evening as played which is a bummer...
  11. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Hi guys - a quick 'heads-up', FD are releasing another game patch in about 19hrs time (sheesh) - so it could be that motion stops again (depending on how much changes in the patch).
    I'm off work tomorrow so will test it out as soon as ED comes back online.
  12. Wagnard
    Wagnardsoft
    5,238Coins
    As last time, will try to do this after work tomorrow.
  13. kev b
    kev b Active Member
    Swindon, UK
    929Coins
    Hi everyone,
    I've just checked out the latest ED patch (patch 2). Happy to report that the motion plugin survived the update and all motion is working as intended. I checked the ship and srv out (in tutorial mode) and all working well - phew!
  14. George Dobransky
    Hungary
    - 43Coins
    Wagnard,
    I just updated the plugin, but at me there is NO any movements in the ship/srv.
    The previous version was worked well. Is that OK at the others?
    Also No activity in tuning center.
    Any suggestions?
    Cheers,
    George
  15. Wagnard
    Wagnardsoft
    5,238Coins
    Show me inside the XML.
  16. George Dobransky
    Hungary
    - 43Coins
    Wagnard,
    My xml seems to be the new one, started with:
    <?xml version="1.0" encoding="UTF-8" ?>
    <!-- 2020-JAN-15 -->
    Is that the right one, or not?
    George
  17. Wagnard
    Wagnardsoft
    5,238Coins
    Yeah it should.
    Maybe something with running gamemanager as admin or something like that?
  18. George Dobransky
    Hungary
    - 43Coins
    Maybe. but I didn't change the rights for these apps..strange..
    I'll try to change the rights vice-versa tomorrow and let you know
    whats happening....
    Thanx for help,
    cheers,
    George
  19. Wagnard
    Wagnardsoft
    5,238Coins
    OK, let me know. If necessary, i'll connect with teamviewer with you and check in cheatengine directly to see if its the pointers that are wrong or if it's simtools related.
  20. Mechromancer
    434Coins
    Thanx for the update. Are you referring to the 1/20 update? The one that says "January Update - Patch 1"?
    I downloaded that one and I'm not getting any motion. Do I need to repatch, even though it's just a XML update?
    Thanx
